Very basic boosted dc2 build
Old Jan 12, 2010 | 08:28 AM
  #26
icucnme's Avatar
Default Re: Very basic boosted dc2 build
It's Rustoleum olive green. Those are the fittings that go to the breather/catch can.
Old Jan 12, 2010 | 09:26 AM
  #27
heeltoehonda's Avatar
I've heard of people using them before.
But what exactly does an oil catch can do? What are the benefits of it?
Old Jan 12, 2010 | 10:44 AM
  #28
icucnme's Avatar
An oil catch can does exactly what it sounds like. It's a can that catches oil.
The benefits of it are prolonged life of your motor and seals.
I would search the topic catch can because it has been gone over a thousand times plus there is a lot of good info on the topic of crankcase ventilation. I'll give you a quick rundown of the basics though. Your motor produces positive pressure in the crankcase "engine block" and in the head "valve cover" You have a factory pcv system "P ositive C rankcase V entilation on your car now that releases the pressure in the block and the breather on your valve cover does the head. It does a pretty good job for a stock motor but once you turbo the car all that positive pressure is increased by a good amount. This is also a good idea on N/A cars to. So by adding to your pcv system by installing extra fittings in the valve cover and running them to a catch can you can eliminate the extra positive pressure being produced in the head. Some people also install fittings in the back of the block. For me this is not needed because I'm not producing a ton of power. So you run two lines from the valve cover. These lines are what the extra pressure travels through to get relieved somewhere. The can is there to allow the air coming from those two lines to be relieved through the filter on top of the can. Since there is oil present in the head and air is being pushed out you will get a small amount of oil residue going into the can. Any oil that comes in with the air will drain down to the bottom of the can. Now you can either hook up a drain back hose from the bottom of the can to the block that way you never have to empty the can and it just keeps recirculating. Or you can just take the can out once a month or so and unscrew the fitting on the bottom and drain it yourself. Hope this clears some stuff up for you.
Old Jan 12, 2010 | 10:48 AM
  #29
Makes a lot of sense. I searched it on google and I didn't get near the amount of info you just told me. Thanks for clearing that up
Old Jan 12, 2010 | 11:23 AM
  #30
mattism78's Avatar
Great work on that 1/4 panel. That's love right there. I couldn't imagine taking on something like that in my garage.
  #31
bks84's Avatar
Loved
Was the car originally a GSR? If not, its a DC4, not a DC2. Nice build/restore though.
Old Jan 12, 2010 | 11:38 AM
  #32
icucnme's Avatar
heeltoehonda-- No problem. Search on h-t if you to know more about it.
mattism78-- Yeah my friend talked me into it but it was worth it in the end.
Cpt. xthread-- Thanks for the compliment on the car. dc2/dc4 it's all the same to me
Old Jan 12, 2010 | 12:04 PM
  #33
bks84's Avatar
Loved
Dont gotta fake the funk... LAWL.
Good luck with it!
Old Jan 12, 2010 | 07:38 PM
  #34
icucnme's Avatar
Good luck with it!
haha yeah true that.
Old Jan 18, 2010 | 06:14 PM
  #35
icucnme's Avatar
I picked my valve cover up today. Had two 3/8's npt aluminum bungs welded in the back. Brought it home and stripped it then a few coats of black vht wrinkle plus. 30 minutes in the oven @ 400 degrees and bam. New oem valve cover.
Old Jan 18, 2010 | 06:22 PM
  #36
^^ Looks good
I just repainted my VC not to long ago also.
Old Feb 3, 2010 | 03:17 PM
  #37
icucnme's Avatar
Well here is an update. I sent my ecu out to xenocron and had it chipped plus a basemap installed so I can drive it to the tuners. I ordered a bunch of parts over the past couple days also. Once it all starts coming in I'll post pics.
Progress cs-2 coilovers - 559
22mm itr sway bar - 110
beaks subframe kit - 50
oem lca's - 40
f brembo blanks - 73
f/r hawk hps pads - 110
ate type 200 fluid - 34
f/r russell speed bleeders - 29
stealthmode ps delete kit - 92
Old Feb 3, 2010 | 08:58 PM
  #38
Where did you purchase this?
Old Feb 4, 2010 | 07:53 AM
  #39
icucnme's Avatar
www.stealthmodeperformance.com
Old Feb 4, 2010 | 08:13 AM
  #40
^^ Thanks
Old Feb 4, 2010 | 10:48 AM
  #41
93egallmotor's Avatar
damn, you know whats up with this gangsta *** DC.....hahaha
Old Feb 4, 2010 | 02:12 PM
  #42
icucnme's Avatar
That's right son! Way better then the same ol' lame k20 swapped eg hatch.
Old Feb 4, 2010 | 02:30 PM
  #43
egvtec's Avatar
Adam the thread is a good reference on everything thats gone down since uve bought the car. Diesel is straight hilarious looking in that one pic.
Old Feb 4, 2010 | 03:06 PM
  #44
ok *** clown, dont make me get my fists bloody....hahaha luv u adam
you're straight hilarious looking......
Old Feb 4, 2010 | 03:17 PM
  #45
icucnme's Avatar
Don't use my build thread to help up your post count. He is laying is his bed. Wtf is hilarious about that.
Urbas is a funny looking dude. You ever just stared at him for a minute. I don't suggest it.
Old Feb 5, 2010 | 09:40 AM
  #46
egvtec's Avatar
I wouldnt mess with me and the boys.... That is the most dangerous skin community in Western Md
Old Feb 5, 2010 | 09:43 AM
  #47
egvtec's Avatar
You know im good looking....
Old Feb 6, 2010 | 01:22 PM
  #48
alright bump this for more updates....and by the way.... ill fight both of you with one arm tied behind my back....
Old Feb 6, 2010 | 02:13 PM
  #49
icucnme's Avatar
Update is my rotors showed up yesterday but my other package is stuck at fedex in hagerstown. Monday my sway bar will be here. Progress is waiting on small parts before they ship out my coilovers. It snowed 2ft last night and because of that my tv is all ****ed up. All pixelated and laggy. My garage isn't heated so all these parts will sit on a shelf until April.
One arm behind your back. Who are you superman
Old Feb 6, 2010 | 04:07 PM
  #50
thats right......super K man
