Return whit race car
Return with race car
Hi!
Im' back from Italy with my new project.....The "specRR" Dark Lady!
Last pics:
The complete topic at this link:
http://translate.google.it/translate...45%26start%3D0
(new project start after page 90)
Shortly i post video of speed test
Best regards
Roby
Last pics:
Best regards
Roby
Re: Return whit race car
Specs:
ENGINE:
-Toda piston 81.25
-Toda Spec C2 cam gears
- Toda valve spring
-Toda timing belt
-AEM adjustalble timing pulleys
- 13,2:1 compression
-Blox 70 mm trhottle body
-Ku Engineering intake manifold worked by specR
-specR 40 mm intake manifold spacer
-specR “Zuccabox” carbon airbox
-RC 370 cc injectors
-higt volume fuel rail
-Automotive fuel prex regulator
-Head worked by Etiliko
-Supertech valve intake/exhaust
-Supertech bronze seat valve
-Carbonetic single carbon plate clutch 1300lb
-balancing cranckshaft
-balancing rods
-ARP bolt rodc
-specR 7075 ergal engine pulley
-Mocal oil cooler with 100° termostatic sandwic plate
-Goodrige aeronautical oil hose
-Toda Racing oil pump
-Samco radiator hose
-Just Intercoolers water radiator with slim cooling fan
-specR oil catch tank
-Accel spark plug wires
-Denso Iridium IK24 spark plug
-Hondata S300 ecu setting by ICE
-Performance Distributors racing mini alternator
-engine wires by specR
-Racing engine mounts
-ATL 30lt racing fuel cell
-Walbro 255 lph external fuel pump
-Goodrige aeronautical complete pipeline fuel hose
-Summit racing fuel fittings
GEARBOX:
-Mfactory 4.2 final drive
-Mfactory 3rd 1.695
-Mfactory 4th 1.384
-Mfactory 5th 1.130
-Mfactory metal plate lsd 60 to 100% lock, 1 to 1.5 way
-specR hyper short shifter
-Torco RTF oil gear
-aeronautical clutch hose
EXHAUST:
-specR 70mm 4-1 headers
-specR 70mm midpipe
-specR 70mm muffler
BRAKES:
-PGS Racing 330x30 composite front disc
-PGS Racing 280x22 composite rear disc
-AP Racing 4 pot front calipers
-Brembo 2 pot rear calipers
-Ferodo DS3000 racing brake pads
-Motul RBF 660 Factory brake oil
-Tilton brake regulator
-Goodrige aeronautical complete pipeline brake hose and fittings
SUSPENSION:
-BC Racing ER adjustable 2 way coilovers
-16 kg front spring rate
-8 kg rear spring rate
-front and rear ITR sway bar
-complete welding frame
-filling frame with polyurethane
-OMP 12 points roll cage
-specR front frame reinforcement
-specR 3 points front upper bar
-specR Xbar
-specR traction bar
-Megan racing gun metal rear lower bar
-Skunk 2 racing gun metal lca with pillow
-specR rear camber kit with pillow
-specR rear toe whit pillow
-Skunk 2 front camber kit
-Energy suspension full bushing kit
-OZ ultraleggera wheels 8X17 et37 modifiled by specR
-specR center cap
-Michelin 20/61-17
-R40 racing composite lug nuts
INTERIOR:
-Takata seat belt harness
-Tillett B6 racing carbon seat
-Key’s racing d-shape steering
-door and interior cover carbon panels
-real titanium shift ****
-real carbon custom dashboard
-Autometer ultralite carbon 5” tachometer
-specR 4 led shift light
-Autometer 3-3/8” digital speedometer
-digital lcd custom display (by Piergsi) with oil prex , oil temp. , water temp., rpm,all alarm setting.
-protoxide digital egt
-digital voltmeter
-fia battery master switch
-OMP 4.2 mechanical system fire extinguisher kit
-real carbon pedals
-complete electric plant by specR
ESTERIOR:
-“Diablo” black matt paint
-White Crow front bumper style by specR
-Backyard special carbon front lip
-specR carbon front splitter
-specR carbon canards
-specR real carbon side skirts
-Mosi carbon real carbon rear spoon style spoiler modifield by specR
-Apr f1 real carbon side mirrors
-custom 2,5 kg real carbon fiber hood
-Password jdm right dry carbon fiber ram air scoop
-Password jdm left dry carbon fiber light cover
-custom real carbon trunk
-D1 Chargespeed +20 mm front fenders
-specR +20 mm flared rear fenders
-specR real carbon fiber roof with air scoop
-specR racing plexiglass glass
-removal wiper motor and arms
-removal radio antenna and fuel door
ENGINE:
-Toda piston 81.25
- Toda valve spring
-Toda timing belt
-balancing rods
-ARP bolt rodc
GEARBOX:
-Mfactory 3rd 1.695
-Mfactory 4th 1.384
-Mfactory 5th 1.130
-Torco RTF oil gear
EXHAUST:
-specR 70mm midpipe
-specR 70mm muffler
BRAKES:
SUSPENSION:
-specR Xbar
-specR traction bar
-specR center cap
-Michelin 20/61-17
INTERIOR:
-digital voltmeter
-real carbon pedals
ESTERIOR:
