Red GSR
Old Apr 15, 2015 | 01:13 AM
  #51
Bitanga's Avatar
10 Year Member
Default Re: Red GSR
Haven't really been working on the caR as much as I would like to. The weather has been terrible and I'm with my Dad every other weekend. Last Friday we weren't doing anything so my Dad asked me if I wanted to work on the car. It was freezing that day but I really wanted to work on it.
We were able to pull the Head off and everything seems good so far. The walls seem great as well. This weekend we will be pulling the rest of the motor out. I've been adding more parts on my list to order; Dizzy bolts, Alternator bolts, etc.. A lot of stuff missing on the motor but can be replaced.
After we pull the motor we plan on sending the head, block, crank, pistons, etc... to my Grandpa's friend to have it hot tanked, honed, inspected, etc.
I wasn't able to take any pictures because my phone died LOL. I'll try this week to get some pictures of what we've done.
Have been ordering things here and there. Still waiting on a bunch of parts to arrive. I hate waiting.
The only thing arrived so far is my Mugen Pedal Set. The matching Dead Pedal from ICB should be here next month.
Also quickly shampooed my floor mats. I need to do a better job but it's not that serious. I'm going to use them anyway.
Old Apr 15, 2015 | 04:35 PM
  #52
Bitanga's Avatar
10 Year Member
Default Re: Red GSR
The piece I've been looking for is finally here!
It's in amazing condition other than a crease in the middle because it was folded.
I need to figure out a way to flatten it out without damaging it.
Old Apr 16, 2015 | 06:20 AM
  #53
EJ1_Ex's Avatar
Default Re: Red GSR
beautiful man!!
Old Apr 16, 2015 | 06:47 AM
  #54
OG Wagon's Avatar
Default Re: Red GSR
Nice! Love the rear mat. My advise would be to complete soak it with water, perhaps after a good cleaning, and then let it sit in the sun with weights just over that crease, across the length of the mat?
Old Apr 20, 2015 | 01:21 AM
  #55
Bitanga's Avatar
10 Year Member
Default Re: Red GSR
We got work done on the R.
So everything looks visually good. Piston #3 Rod Bearings were spun. The crank isn't scored too bad visually but we'll see when we have the machine shop inspect it.
She'll be on the road soon! So now it's the time to order everything I need! Yay
OEM ITR Spark Plug Wires or NGK
NGK Laser Platinum Spark Plugs
Hasport Motor Mounts
ARP Head Studs
ARP Rod Bolts
Thermal Intake Manifold Gasket
Thermal Throttle Body Gasket
OEM ITR Head Gasket
OEM ITR Valve Cover Gasket Set
OEM ITR Exhaust Manifold Gasket
OEM ITR Camshaft Seals
OEM ITR Fuel Filter
OEM ITR Distributor O-Ring
OEM ITR VTEC Solenoid Gaskets
OEM ITR Front Main Seal
OEM ITR Rear Main Seal
OEM ITR Water Pump
OEM ITR Oil Filter
OEM ITR Oil Pump
OEM ITR Oil Strainer
OEM ITR Oil Strainer Gasket
OEM ITR Oil Pan Gasket
OEM ITR Piston Rings - waiting for machine shop
OEM ITR Wrist Pins - waiting for machine shop
OEM ITR Rod Bearings - waiting for machine shop
OEM ITR Main Bearings - waiting for machine shop
OEM ITR Thrust Washers - waiting for machine shop
OEM ITR Timing Belt
OEM ITR Timing Belt Tensioner
OEM ITR A/C Belt
OEM ITR Alternator Belt
OEM ITR Power Steering Belt
OEM Turn Signal Socket
OEM Seat Bolt Covers
OEM Front Bumper Clips
OEM ABS Pump Bolt
OEM Exhaust Bolts - Header/Cat
OEM Fan Switch
OEM Tow Hook Bolts
Shifter Bushings
Secondary O2 Sensor
The list isn't final. Just a good idea on what I will need or want.
To the Pictures!
Head Off!
Tranny Out!
Block Out!
Can't wait to have heR running!
Going to clean the bay up real good. Any recommendations on what to use?
Yuck!
Block Torn Apart - Ready to be dropped off at the machine shop.
Dirty a** tranny
What a mess!
Old Apr 20, 2015 | 11:56 PM
  #56
Bitanga's Avatar
10 Year Member
Default Re: Red GSR
More Parts Arrived!
OEM Goodness
Carbon Fiber Driver Vent
UGH!
Oil Filter (GSR), VC Gasket (GSR), Oil Pan Gasket (GSR), Wheel Studs, Strut Bar Sticker, Center Console Cap
Old Apr 21, 2015 | 04:56 AM
  #57
lub's Avatar
lub
Default Re: Red GSR
This is gunna be good. I have Integra-envy.
Old Apr 21, 2015 | 08:46 AM
  #58
kcarroll491's Avatar
Default Re: Red GSR
I would kill to be doing this to my car. First world daily driver problems....
Old Apr 21, 2015 | 10:28 AM
  #59
StreetLethaleg6's Avatar
Default Re: Red GSR
hahah truth, that list of oem honda ITR parts will cost something serious lol
Old Apr 26, 2015 | 10:29 PM
  #60
Spec R's Avatar
Default Re: Red GSR
I dont post often on HT anymore but this was so worth it.
Its refreshing to see other people with the same approach to my cars. buying OE parts brand new isnt cheap! but OE is best.
Good luck with all the builds, and keep these beautiful cars safe.
jay_see_eye
Honda CR-V & Element
42
Feb 9, 2013 08:55 AM
vc
May 20, 2010 10:36 AM
boostedcivicsir
Feb 20, 2007 10:12 AM
PornoPanda
Apr 23, 2004 01:36 PM
Aussie_ITR-0239
Dec 17, 2001 01:53 PM
