Project time attack del sol build
Old Dec 10, 2011 | 02:19 PM
  #51
Ty.'s Avatar
Ty.
Default Re: Project time attack del sol build
brake setup done pic and new lugs(yes its my 3rd set)
dont mind tie rod end. i have new ones on the shelf!
valve cover done ( i love how it looks against the gold)
catch can test mounted
boltboys b series engine kit
drivers side headlight/corner/fog wire tuck
on the ground.... 3 years later
An fittings for catch can (small write up)
Measure steel braided hose to length needed. Wrap with electrical tape tightly 5 times around. Then wrap with painters tape. Use large 4-5 inch cutting wheel and cut as smooth and straight as possible.
Remove all tape
Take fitting and rub small amount of wd40 on inner edge and slide/twist over braided hose. U may need to use small flat head screw driver to help on any uneven braided spots
Take electrical tape and wrap just under fitting to make sure u have a good spot on how far fitting is in (during next step this is helpful to know if when screwing in rest of fitting that the hose is not just coming out other side)
Dip end of fitting into motor oil then slide into hose end and start threading (having a vise makes this alot easier.( make sure to cover vise so it does not scratch fitting. I just wrapped it with electrical rape to make a nice soft surface to contact fitting)
Using boxed end of wrench tighten till tight but don't over tighten as fitting are aluminum and will break!
Check to see if hose is tight in place and walahh ( now repeat with other side)
cleaning up engine and trans, and painting to new!
Trans
Engine
BLING!
catch can fittings in rear of block.
New oem S2000 clutch master
Clutch master spacer
oem mounting
side by side oem vs s2k
s2k with spacer and firewall seal
installed!!
look how clean!
act clutch, flywheel, and pressure plate installed
engine and trans back together
bolted in, chasebays clutch line ran
money shots
cooling parts showed up!
koyo r core radiator, mishimoto fan and shroud, pjdm radiator stay, samco hoses, koyo radiator cap(not pictured)
iPhone pic
skunk2 goodies:
68mm black series throttle body
composite fuel rail
black series billet cam seal
yum ... wilwood and chasebays!
New part in mail. Multi purpose of this
Ground wire kit
Old Dec 10, 2011 | 02:20 PM
  #52
Ty.'s Avatar
Ty.
mods to date
Engine/trans
B18c1 block
B18c5 (ITR)head
B18c1 transmission
B18c5 (ITR)intake manifold
Port match intake manifold to 68mm
Hondata intake manifold gasket
Skunk2 fuel rail
Skunk2 cam gears
Skunk2 Throttle body
Skunk2 Cam cap
Arp head studs
AEM intake
Act 6 puck clutch
Act heavy duty pressure plate
Act flywheel
S2000 Clutch master
Innovative motor mounts
ChaseBays clutch line kit
ChaseBays Fuel Tuck
ChaseBays Engine harness
ChaseBays ground wire kit
Walbro fuel pump
Koyo Radiator
Koyo radiator cap
Mishimoto fan and shroud
SAMCO Hoses
B&R Catch can kit with AN fittings
Non-power steering rack
Bolt boys engine bolt kit
Bolt boys transmission bolt kit
All new oem gaskets
Oem timing covers
Candy blue valve cover
Shaved and Painted engine bay
Fuse box relocated
Suspension
Tein SS coilovers
Skunk2 front camber kit
Skunk2 rear camber kit
ASR rear sub frame brace
ASR rear Sway Bar\
ASR end links
Function 7 lower control arms
Brakes/Wheels:
ChaseBays brake booster delete plate
ChaseBays Brake Propotioning valve tuck
Oem reman calipers
Hawk brake pads
Wilwood Master cylinder
Wilwood blank rotors
Goodridge Stainless Brake lines
Konig mag blue wheels
Nitto neo-gen tires
Exterior (not even close to finished)
JDM EG2 headlights
Custom rear spoiler
Interior (not close to finished)
JDM all black del sol seats
Personal Steering wheel
Nrg quick release hub
Old Dec 11, 2011 | 09:22 AM
  #53
wstmsol's Avatar
great progress !
Old Dec 12, 2011 | 06:13 AM
  #54
Ty.'s Avatar
Ty.
Originally Posted by wstmsol
great progress !
Thanks
Old Dec 12, 2011 | 07:37 AM
  #55
markspan6243's Avatar
Flattery Will Get You Everywhere
ugh makes me miss my del sol so much but why full interior but no carpet?
Old Dec 12, 2011 | 01:36 PM
  #56
bisscrac's Avatar
man that bay is sooo clean
Old Dec 12, 2011 | 01:54 PM
  #57
CBURKE's Avatar
great work!!!
Old Dec 12, 2011 | 03:46 PM
  #58
Ty.'s Avatar
Ty.
not really much interior in a del sol. I put it together without the rear par of interior and it just didnt flow. also i like having the rear cubbies!
Old Feb 2, 2012 | 05:38 PM
  #59
dc292177917's Avatar
nice project mate!!
lots of goodies
just a quick question
do u have some pictures that tell me where can the wires/cables go thru the rear firewall?
thanks!!
Old Mar 27, 2012 | 04:04 PM
  #60
BizzSol's Avatar
hey man nice build, lets see more updates its looking to good to stop!
Old Mar 27, 2012 | 05:50 PM
  #61
Tuner Eddy's Avatar
sick!
Old Mar 27, 2012 | 09:50 PM
  #62
ChaseIntegra's Avatar
Good stuff.
Old Jan 6, 2013 | 10:16 AM
  #63
crazzysol812's Avatar
updates?
Old Jan 6, 2013 | 11:29 AM
  #64
wstmsol's Avatar
this is great
Old Apr 15, 2013 | 09:00 PM
  #65
Ty.'s Avatar
Ty.
Wrapped and ready to make the 600 mile trek for paint
Old Jun 22, 2013 | 03:52 PM
  #66
again updates?
Old Jun 24, 2013 | 05:40 AM
  #67
b20hatchek's Avatar
Updates?????
Old Jun 24, 2013 | 11:50 PM
  #68
Brandi18c1's Avatar
Hopefully soon. I was all excited to see it painted
Old Jun 25, 2013 | 05:28 PM
  #69
EG6_LS_BOOST's Avatar
Nice
90dteg
Appearance Build Threads
17
Sep 11, 2009 07:50 AM
714phil
Jun 10, 2006 08:06 AM
DavisC22
Apr 24, 2006 01:52 PM
92 civic VX B18c
May 16, 2005 05:40 PM
Mr. Self Destruct
May 3, 2005 07:35 AM
