My Wheel Build thread!
Old Nov 29, 2007 | 05:19 PM
  #26
caustic.'s Avatar
mike lawry
Looking good.
Old Nov 29, 2007 | 05:30 PM
  #27
pinoy2o9's Avatar
Default Re: (caustic.)
keep this updated. im liking the progress
Old Nov 29, 2007 | 05:31 PM
  #28
95greenlude's Avatar
Default Re: (pinoy2o9)
one on the wheels will be done by the end of the night....
i'll show the finished product
Old Nov 29, 2007 | 05:49 PM
  #29
NazVil86's Avatar
Default Re: (95greenlude)
in for final results- looks really good man
Old Nov 29, 2007 | 06:01 PM
  #30
just Touge's Avatar
looks sick Jared.
Old Nov 29, 2007 | 06:42 PM
  #31
dt98gsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinoy2o9 &raquo;</TD></TR><TR><TD CLASS="quote">keep this updated. im liking the progress</TD></TR></TABLE>
x2
I always like refurbished wheels done right
Old Nov 29, 2007 | 06:47 PM
  #32
Default Re: (dt98gsr)
spraying on the last coat of clear right now....
i'm going to take off the tape tomorrow, i'll post some pics up after i do
Old Nov 29, 2007 | 06:50 PM
  #33
EF9 JAMS!!!'s Avatar
do you know if there is some sort of torque specification on the rivits in order for i would guess the wheels not to bend or warp???? like a a wheels sealer of some sort? also. NICE JOB YO!!!! this is like the third wheels refinishing job thread i've seend and i am impressed. gonna do my super fins shortly.
Old Nov 29, 2007 | 07:25 PM
  #34
Default Re: (EF9 JAMS!!!)
^i've gotten advice to go anywhere from 15-25 ft lbs....and when i took off the bolts they had the blue lock-tite on them....so i'm going to use it again....
Old Nov 30, 2007 | 08:32 AM
  #35
did you put the loctite on only the rivit studs or along the inner lip aswell?
also about how long on each grit of sand paper did you take before you moved on to the next higher grit? (timewise not too sure if you got that)
Modified by EF9 JAMS!!! at 10:05 AM 11/30/2007
Old Nov 30, 2007 | 08:43 AM
  #36
Loco-B's Avatar
cant wait to see finished product!!!
youll beat me in the race to finish!!!! but its winter here.....not like my wheels will do any good on the car right now!!
Old Nov 30, 2007 | 08:48 AM
  #37
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9 JAMS!!! &raquo;</TD></TR><TR><TD CLASS="quote">did you put the loctite on only the rivit studs or along the inner lip aswell?
also about how long on each grit of sand paper did you take before you moved on to the next higher grit? (timewise not too sure if you got that)</TD></TR></TABLE>
i havnt put them back together, so i'll let you know what i do when i do.
i used 220 until i couldn't see any casting/machining marks (i probably took the longest with this grit)
moved onto wet 320 when all of ^ was gone. i moved on to each grit when the marks from the other grit were gone, which left me with finer sandpaper marks....
Old Nov 30, 2007 | 09:01 AM
  #38
Loco-B's Avatar
i had to start with 60 grit....
the raw cast aluminum wouldnt clean up on anything less. I still have to spend the most time on this grit. But it seems as though every other grit polishes up in half the time.
Old Nov 30, 2007 | 09:07 AM
  #39
NICE. i think i am going to go ahead and start my own wheel refinishing thread.
def subscribed
i'll let you know as soon as i get my ish going!
Old Nov 30, 2007 | 09:12 AM
  #40
Default Re: (Kurumi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kurumi &raquo;</TD></TR><TR><TD CLASS="quote">i had to start with 60 grit....
the raw cast aluminum wouldnt clean up on anything less. I still have to spend the most time on this grit. But it seems as though every other grit polishes up in half the time. </TD></TR></TABLE>
60 wow
there's still some bumps, but this was the first wheel, i'll probably go down to 180 in some areas on the next wheels......
Old Nov 30, 2007 | 09:23 AM
  #41
Loco-B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95greenlude &raquo;</TD></TR><TR><TD CLASS="quote">60 wow </TD></TR></TABLE>
mine might have been a little more rough to start.
Old Nov 30, 2007 | 10:05 AM
  #42
yea, it definatly was
Old Nov 30, 2007 | 10:11 AM
  #43
InvaderJim's Avatar
Can't wait to see these done.
Nice lude.
Old Nov 30, 2007 | 10:12 AM
  #44
Newborn_'s Avatar
Grace Under Pressure
Default Re: (InvaderJim)
Looking forward to seeing how these turn out, i love BBS wheels.
Old Nov 30, 2007 | 04:27 PM
  #45
Default Re: (Yoshimi_Vs.)
more pics of finished wheels!!!
Old Nov 30, 2007 | 04:44 PM
  #46
McLovin's Avatar
can't wait to see the finished wheels. nice work
Old Nov 30, 2007 | 04:47 PM
  #47
Smokinsax's Avatar
The Boot
im in for some results.
Old Nov 30, 2007 | 04:57 PM
  #48
Fern413's Avatar
Default Re: (Smokinsax)
lookin nice
Old Nov 30, 2007 | 05:15 PM
  #49
REAL TIME's Avatar
Default Re: (Fern413)
subscribed
Old Nov 30, 2007 | 05:38 PM
  #50
SHG_EasyE's Avatar
Default Re: (REAL TIME)
nice ... in for the final product
