My integra build thread
I've already started on my local forum but i will continue to add on here as pregress continues.
Got the car pretty much trashed, non running motor,crap interior, bad paint,ect ect. Only got it because it was a straight frame.Will have progress whenever i have time to work on it.
plans for the car?
Exterior-
fix all dents/dings
replace driver door
replace both fenders
complete respray of nhbp for the entire car
fix hazed up headlights
96 spec itr lip
all red tails
mudflaps
STOCK exhaust
Crazy colored Mesh wheels with 195-45 tires(i'm planning to dump this thing)
and whatever else i can think of.
Interior-
rip all all brown interior out
remove sound deadening(where can i get dry ice around pensacola?)
tint
full black interior conversion(got most of everything already)
Motor wise-
replace existing ls motor(bent valves)
clean engine bay
wire tuck
abs delete
shave
get ac working
spray bay pink
J32 lsd 6 speed swap whenever i finish the rest and start to round up parts.
Suspension-
omni power lca's
Koni yellows/gc coilover setup
f/r camber kit
asr subframe brace with itr sway
Security-
kill switch
.40
Time frame of completion will be end of december for everything minus j swap, summer for the swap.more when i get there and decide to do it.
on to the pics!
Day i got her.
Started to rip things out.
today, pulled the head, the bottom end is in good condition, head is bad so i'm going to put another one on. Most likely will be running tommorow.
plans for the car?
Exterior-
fix all dents/dings
replace driver door
96 spec itr lip
all red tails
mudflaps
STOCK exhaust
Interior-
tint
Motor wise-
clean engine bay
wire tuck
abs delete
shave
get ac working
spray bay pink
Suspension-
omni power lca's
f/r camber kit
Security-
kill switch
.40
on to the pics!
Day i got her.
Got around to messing with it today- pulled/gave away the interior today, other than the dash. Next for the interior is to remove the sound deadening.
pulled the head off to discover it had no dowel pins, bent valves, valve stem seals were dead. Went to go replace valves/seals halfway through i discovered a valve guide was broken. Time for a new head.
got around to working on it today. sourced out a black driver door and driver fender. I found out both windows and the sunroof work very well without any hesitation so i'm pretty happy about that.
old door
Replacement
New fender and everything lined up.
still awaiting my head to be finshed so i can get her running, source out a passenger fender so i can begin bodywork and swap the interior out.
old door
Replacement
picked up some goodies. full turbo kit for the ls for the time being so i don't get bored before the j swap.
b series mini ram manifold
tial 40mm wastegate
.50 trim turbo
tial 50mm bov
custom piping
all braided oil lines
an oil return
tapped oil pan
boost gauge
blitz turbo timer
custom dump tube
custom 3 inch dp
dsm 450cc injectors
walbroo 255
adjustable fpr
very capable of 300whp with tuning.
tial 40mm wastegate
.50 trim turbo
tial 50mm bov
custom piping
an oil return
tapped oil pan
boost gauge
blitz turbo timer
custom dump tube
custom 3 inch dp
dsm 450cc injectors
walbroo 255
adjustable fpr
got some time again. started to install the new black interior.
thanks rabbit for the seats, havie for the dash n panels, and kirk works for all the odds and end.
Got the new apexi turbo exhaust on.
Rear windshield WIPER delete.
before-
after-
Picked up a competition clutch stage 4 clutch also.
before-
after-
went and got some new rollers today. due to the very low offset, i will need to roll the fender pretty hard to have them fit correctly and give it some more negative camber.
check out the lip. lols, car is sitting on the tires in the rears.
many cars don't even have rear windshield wipers to begin with, heck, i never even used mine when i drove my hatch through the rain...
I don't think he was doing it to save weight. It just looks better. And your not looking through the rear windshield unless you like to drive around in reverse bro.
Btw car looks awesome already. Day and night difference.
i typod that wiper thing. it does look better in my opinion and i don't plan on using a rear wiper anyways.
got degreaser and busted a toothbrush out to start cleaning the engine bay today.
stripped/Painted the valve cover satin lime
fresh head about to go on.
got the bumper on.
got the bumper on.
