Mr_ET's EJ8 project thread
Old Feb 6, 2010 | 06:05 AM
  #51
Mr_ET's Avatar
Default Re: Mr_ET's EJ8 project thread
Finally picked up the head today!
Skunk2 retainers
Skunk2 Pro series valve springs
Skunk2 Pro series High compression STD size valves
Port & Polish
Also found some rockers today so I will be swapping those soon!
Next step is a timing belt and top end gasket set and I can start buttoning her up!
Old Feb 8, 2010 | 11:44 PM
  #52
J.M.'s Avatar
Looking good! Can't wait to see more progress.
Old Feb 9, 2010 | 03:52 AM
  #53
Kyle R's Avatar
Clean!
Old Feb 11, 2010 | 04:21 PM
  #54
DVDr's Avatar
Great project.
Im not the only one who had initial faith with the D16y7 . But ofcourse time for a more fun engine setup.
Old Feb 11, 2010 | 05:09 PM
  #55
Deetz's Avatar
Crazy Honda Guy
Looks like the head turned out exactly how you wanted, nice!!
Old Feb 13, 2010 | 09:20 PM
  #56
Mr_ET's Avatar
Yeah I'm pretty happy with it now I need some lube for the rockers and cams. I will use my current rockers and I'm sure it will be fine.
I should have all the gaskets needed to finish the engine assembly in a couple of weeks.
Right now I am missing:
the vtec solenoid green plug sensor that screws into the vtec solenoid housing
a knock sensor
a B16 VSS
flywheel bolts
transmission bolts
throttle body
2.5 inch test pipe
RMF replica header
2.5 inch exhaust
SI engine mount post (drivers side)
SI throttle cable
and of course a tune.
Old Mar 15, 2010 | 08:48 PM
  #57
shogee's Avatar
looks good
Old Apr 8, 2010 | 04:44 AM
  #58
Mr_ET's Avatar
Ok I went a little picture crazy today
68MM Blox Throttle Body
Car in its current state, I will soon start pulling the engine
Swapped out the exhaust for now for a stock piece because of this:
crap welding I plan to cut the piping and reuse the muffer, here it is cleaned up a bit
Picked up a couple OEM filters and some BKR7E plugs since its 12:1 compression
Finally found a knock sensor
with its plug
  #59
Mr_ET's Avatar
Continued
gaskets/seals galore
All OEM
Some engine assembly pics ARP head studs
OEM head gasket
Little trick
Don't forget this when assembling
Resprayed VTEC solenoid and new gasket
OEM thermostat
SIR engine mount post and studs
Compared to a GSR one
Old Apr 8, 2010 | 04:45 AM
  #60
Mr_ET's Avatar
Continued
Some work on the Skunk2 Pro series intake manifold
Throttle body installed
  #61
Mr_ET's Avatar
Here are a few more pics the engine with its cams and gears
baffled pan for road racing
stripped valve cover
Old Apr 8, 2010 | 06:01 AM
  #62
ken9's Avatar
Look dope..
Old May 4, 2010 | 04:35 AM
  #63
Mr_ET's Avatar
Update!
Here are a few pics of the progress/mess
repainted the mounts
Some wiring
Old alternator belt that had seen better days
New belts and exhaust gaskets
New belts on
New rad
Interior mess
Before I pulled the engine last week:
Still waiting on the rear mount and now I have to source a longer fuel return hose and evap canister hose.
Wiring still needs to be finished for VTEC
completely repainted trans and all brackets, thx EFHatch!
Repainted shield on OEM Cast JDM ITR header
S2 Pro Series intake manifold with ITR throttle cable bracket and SIR throttle cable
Yes I am keeping power steering on a race car you try parking with no P/S on r compounds
New rad
Old May 26, 2010 | 07:50 PM
  #64
Mr_ET's Avatar
First let's start with what didn't go so well:
Integra rear bracket vs SIR, thanks 78si for saving the day because I was hooped for the dyno date tomorrow without that part.
Correct one at the botom, you can stt it is much shorter
New rear mount, engine feels solid now
Axle seal needed to be changed and I also got a 2.5 inch blox flange to get that welded to my cat
Projekz hooked me up with a Skunk2 short shifter
Final wiring
all she needs is fluids and she is ready to start tomorrow
The only thing that stresses me out is the cams, I had the machine shop degree them but they look to be almost at 0 0 so I will get Toma to adjust them on the dyno so when I hit VTEC we don't have valve to valve contact
Old May 26, 2010 | 07:51 PM
  #65
Mr_ET's Avatar
So update:
Finally hit the dyno with Toma after fixing all the small problems.
Very dissapointed with the final numbers. With that said this car is running a full stock exhaust from an ex/si with a stock integra cat converter.
Is it costing me a ton of power, I'm not sure but VTEC made pretty much 0 power. Maybe one of you guys has an idea what is happening.
low cam tuning, alright making good power up to now...
VTEC crossover, not making any more power until really up there
Final numbers VTEC is set at like 7200rpms
Log of a/f and power/torque
Cams are set to 0 intake and +4 exhaust as per skunk2. I also had Precise degree them but it didn't even look like they did anything so I am pretty sure they didn't degree them but still charged me for it...
They also didn't give me the P2V or V2V so hesitant to change the cam gear settings.
Thoughts comments?
Old Jun 9, 2010 | 08:01 AM
  #66
go hard jersey's Avatar
isnt that dyno known as the heartbreaker?
bumpytouge
Appearance Build Threads
Nov 10, 2016 08:36 AM
Jud-Boosts
Nov 18, 2010 06:47 AM
ef9arroyo
Feb 3, 2009 03:55 AM
whitecivic11
Dec 19, 2008 09:16 PM
coolusername
Northeast (Sales)
21
Feb 27, 2007 01:57 PM
