Logan's 7th gen civic
Old 09-26-2014, 11:37 PM
  #76
Loganej8's Avatar
Default Re: Logan's 7th gen civic
Originally Posted by slowDB7
Is the tensioner possibly bad?
Yes, I am thinking that is my problem. I will open it up tomorrow and see. I am willing to replace it as a ditch effort to get her to run. After all the tensioner is responsible for stopping the belt not jumping. Thank you for your suggestion.
Ps: pray my valves are okay
Old 09-27-2014, 08:45 AM
  #77
slowDB7's Avatar
Did you replace the timing belt, or is it the one that came on the new engine?
Old 09-27-2014, 08:57 AM
  #78
Loganej8's Avatar
it is a new honda belt. I checked the part number and it is the correct belt.
Old 09-27-2014, 04:05 PM
  #79
Loganej8's Avatar
took the timing covers off. the motor is still timed. looking for a new solution.
Old 09-30-2014, 04:12 PM
  #80
Loganej8's Avatar
Got the motor running. I am trying find why it is loosing so much coolant.
Does anyone have any experience with 7th gens? It doesn't smoke but it looses a lot quickly and the fans don't turn on but they work when tested. The ac and heater work also temp reads normal.
New head gasket, water pump, hoses thermostat. Loses the same amount of coolant as my last motor.
I'm stumped.
Any ideas??
Please and thank you
Old 10-17-2014, 06:41 PM
  #81
Loganej8's Avatar
Untitled by Logannn00, still not running but here is a picture
Old 10-17-2014, 08:09 PM
  #82
Silky_7's Avatar
Looks great. So clean
Old 10-18-2014, 09:23 AM
  #83
Loganej8's Avatar
Thank you!
I was able to borrow a snap-on coolant system pressure test tool from my uncle. This morning I put in a few minutes and did the test. My results were not what I wanted; quickly loosing pressure in about 3o seconds. I also started up the car to see white smoke that did not smell like coolant but I had not seen this before.
Other symptoms; coolant level when down as a revved the motor few bubbles while in idle. fans do not work, heat works no coolant on the ground or sub frame.
I am thinking bad head gasket? what do you think?
Untitled
Old 10-19-2014, 02:47 AM
  #84
slowDB7's Avatar
Sounds like a headgasket, hows the oil looking?
Old 10-19-2014, 08:48 AM
  #85
StreetLethaleg6's Avatar
great start bro. I love these cars, they make perfect DD, fun and reliable. but as far as a actual performance car, they are the worst, worst suspension of the hondas and etc. I had a 03 civic EX, that i used as my daily for like 4 years with no issues, great car, i loved. They def weren't built with performance in mind. If you want a more serious performance wise care with potential, similar-ish go with a rsx and use this strictly as a daily.
Old 10-19-2014, 05:58 PM
  #86
Loganej8's Avatar
Thank you for the opinion SlowDB. on that note I am going to resurface the head and replace the head gasket again.
Lethaleg, I also really like these and I agree about the performance part. The car is currently my project car because I just bought an EG to get me around.
[url=https://flic.kr/p/pEwq5M]
My plan for is to actually get another car. In search of dc5 through IAA for part out. Looking for motor, swap parts, seats and the brakes. Looking to sell my D17 motor to help make up the cost. Also interested in buying swap not in a car.
Old 10-19-2014, 06:15 PM
  #87
Loganej8's Avatar
To keep this thread from sucking here are some pictures I have not posted.
Old 10-19-2014, 07:56 PM
  #88
slowDB7's Avatar
I love eg sedans looks good lol
Id say i would buy that d17 but your across the country
Old 10-19-2014, 08:03 PM
  #89
Loganej8's Avatar
will ship. im sure shipping wouldnt be bad. I would also include a donor motor with it.
Old 10-21-2014, 01:52 PM
  #90
Loganej8's Avatar
traded doing my buddies endlink on his girls car for this. also got to use my new grinder to get the seized nut off, the ford rust would not let go
Old 11-24-2014, 03:21 PM
  #91
Loganej8's Avatar
Hey guys I did another pressure test on my coolant system and got a good result. I am pursuing a air bubble in the block. I have tried normal burping techniques but no luck yet. has this happened to any other D17 users?
Also working on restoring the shift cable assembly on the trans its turning out cool ill post some pictures soon.
Old 06-17-2015, 08:32 PM
  #92
Loganej8's Avatar
New d17a from Hmo with 40k to replace the old one. I am really excited to drive the car again runs strong I just have a few things to button up. anyways here are the pictures I collected during the process.
I made a gnarly clear combo to clean up the bolts
pulled the old swap out
I wish I would have painted the new motor like I did with this one.
simple green everything
[url=https://flic.kr/p/uxQ6t9]
[url=https://flic.kr/p/uLSsGf]
Put that **** back together
also always keep your clutch tool in a safe place!***
some of the new parts
Picked up some old NT-03 Enkie wheels 17s still look small. Plan is to get some meaty tires on them for race car look.
washed
I cleaned up this thing
no picture back on the car but it looks like this
Old 06-18-2015, 04:00 PM
  #93
slowDB7's Avatar
Lets hope this engines good
I finally got my new d17 swapped into mine and its got a blown headgasket
Old 06-18-2015, 08:36 PM
  #94
Loganej8's Avatar
I have put a hundred miles on it so car. it looses a little coolant and has a slight oil leek that I have found. I hope to have the car all the way done soon. Where did you get your d17 from?
Old 06-19-2015, 06:36 AM
  #95
slowDB7's Avatar
Someone local had a full em2 parts car, so they said i could have the engine for 200
Old 06-19-2015, 07:35 AM
  #96
Loganej8's Avatar
Seems like this motor is loosing coolant too so I need to figure out what is going on here and also need to fix my leaking vtec sensor. other than that the new motor feels good a strong.
Do any of you have problems loosing coolant in their 7th gens?
Old 06-24-2015, 05:21 AM
  #97
Jar2005's Avatar
Nice build man. Always happy to see another EM2 owner (yours is in way better shape than mine lol).
Two suggestions about the coolant leak:
a) When I changed my headgasket because it was on it's way out (you could tell because after driving for a while, if you open the cap to the radiator exhaust gas would be coming out ) I actually put the head gasket on wrong/backwards. It's hard to tell, but on the OEM one there is a small triangle shaped tab that lines up with an equal shaped tab on the block. Maybe it's not sitting right so coolant is escaping there?
b) these blocks aren't so bad that both motors should be leaking coolant already (especially the one with 40k). Maybe it's part of the coolant system that you haven't replaced like the heater core or the radiator?
TL:DR- Check headgasket direction, heater core, and radiator
Good Luck!
Old 06-25-2015, 07:23 AM
  #98
Loganej8's Avatar
Good Luck!
Hey Jar thanks for checking in, there seem to be a few of us 7th gen people on HT these days. The last motor was junk but the new one is working now.
I kept filling the new one up it needed less than a cup each time and has stayed full for about 200 miles.
I did however fry a wheel bearing on my front passenger hub. Im going to replace both front wheel bearings with parts I ordered from honda when I get back from camping
Old 06-26-2015, 12:58 PM
  #99
Trueeast's Avatar
love the coupe. super clean.
Old 06-29-2015, 08:19 AM
  #100
bbarbulo's Avatar
i've never had any coolant loss issues in my EM2. I would just bypass the rad and heater core, then pressure test the engine alone. if it passes, test rad, then heater core independently with the pressure tester. that should at least narrow down the scope of the problem. good luck with your beautiful ride.
BTW, i just did front wheel bearings on mine, just be equipped with a big hammer and blocks of wood to pound out the old stuff. i used a press to get it back in, that was the easy part, but there is no way to get it in a press to press out the old ones. hammer is the only way.
Quick Reply: Logan's 7th gen civic
