Caoboy's OMG WTF did I get myself into project thread
#52
Re: Caoboy's OMG WTF did I get myself into project thread
That crankshaft keyway is fucked. Most likely someone used the incorrect key at some point and the crank pulley spun and damaged the crankshaft snout. Is the crank pulley damaged too? Ouch
#53
-Intl Steve Krew
The pulley does not look bad. I will reinspect it.
I could tig weld it together if I really need to
Parts started showing up today...
#54
Tig the pulley to the crank? I definitely wouldn't recommend that! Although you could possibly build up the damaged end with weld and turn it down until it was the right shape again. I'm honestly not sure I'd recommend attempting that though either.
#57
-Intl Steve Krew
Clutch kit, timing belt, IM gasket, middle timing cover, tension bearing, and valve adjustment tool have arrived.
Progress CSII coilovers went in today. Ride height gets fine tuned tomorrow or Sunday (most likely Sunday) and the alignment shop is going to change the inner tie rod and align the car on Monday.
I am waiting on Majestic Honda to ship my order of parts. Once I get that, I will continue updating you. Now why don't you go update or make your own build thread!
#59
-Intl Steve Krew
Dur Da Dur
@hondur you called it, there's a nice groove in the shaft right now.
Which seal did you use? Rockauto has the Timken seal for a decent price.
amazon's price....
Amazon.com: Timken KWK99315 Oil Seal: Automotive
amazon's price....
#65
-Intl Steve Krew
You came across some really good information about the transmission I might be able to use those sites for later uses
#68
I really don't know
Wow- did you have AA write the first post for you?
I just saw a post in GDD that mentioned something called Honda Tech so I figured I would check it out!
Will be back
Will be back
#70
-Intl Steve Krew
-Intl Steve Krew
Long story short, I didn't get to go to recess.
I'm detailed, it's a problem I guess.
Or think of this thread like a Bollywood movie, but instead of musical breaks, there are pictures.
#73
I really don't know
I remember in like first or second grade was not allowed to go to recess until I rewrote a 'shorter' summary for a short story.
#75
-Intl Steve Krew
