95 integra gsr sedan - db8 build.
Old 03-05-2021, 08:56 AM
  #76
90da4dr's Avatar
Default Re: 95 integra gsr sedan - db8 build.
Ordered a oil pan baffle kit about a year ago from chuck chainz. Finally got it installed.
Old 03-05-2021, 09:00 AM
  #77
90da4dr's Avatar
Made some progress getting the motor together
Old 03-15-2021, 05:32 AM
  #78
90da4dr's Avatar
Long weekend. Finished assembling the motor. Bolted up trans stuff. Then installed it into the car. Found a crack in the timing belt... Replaced timing belt. Need to wrap and install header, radiator, then fluids. Hopefully will continue today.
Old 03-17-2021, 11:19 AM
  #79
90da4dr's Avatar
FIRST START!!!!!
Old 03-17-2021, 11:40 AM
  #80
danteisme's Avatar
Awesome!!!
Old 03-17-2021, 12:12 PM
  #81
90da4dr's Avatar
Originally Posted by danteisme
Awesome!!!
Thanks!
Old 03-21-2021, 05:36 PM
  #82
90da4dr's Avatar
Running into a couple of issues, coolant leak, vtec solenoid leak (though it was the head gasket), smokes when I accelerate after decel. Think I pushed the valve stem seals too far down when installing them. Starter died lol. But got street tuned this weekend so I can drive it around to break the motor in. It felt strong to 7800. Still will get dyno tuned once I resolve the issues.
Old 03-23-2021, 08:14 AM
  #83
chuck chainz's Avatar
Hope you get it all resolved soon. Looks/sounds like it'll be really fun to drive!
Old 03-24-2021, 03:29 AM
  #84
90da4dr's Avatar
Thanks, just have to muster up the energy to continue lol.
Old 03-24-2021, 03:46 AM
  #85
90da4dr's Avatar
Realized I haven't listed what's in the car. I call this a budget build even though it was expensive to me.
Head:
b18c1 stock port
new gsc valve guides
new gsc valves
new oem seals
blox dual springs and retainers
blox type c cams
home ported skunk2 pro rep manifold
skunk2 alpha 70mm throttle body
3.5 intake with hybrid racing velocity stack and filter combo
Golden Eagle lsvtec kit
Block:
b20b
ycp high comp pistons
eagle rods
king xp rod and thrust bearings
oem main bearings
polished crank
vhb engines ported oil pump
ATI damper
ARP head studs
Trans:
GSR trans
mfactory helical lsd w/ stage 1 race pack
gsr flywheel
ebay stage 3 sprung 6 puck
Exhaust:
1320 toda rep header
2.5 test pipe
2.5 yonaka piping with vibrant resonator and vibrant muffler
ECU:
p72
moates daemon v2
honda tuning suite.
Suspension:
Progress cs2 coilovers 450f/450r
Progress rear sway bar
Hardrace rubber bushings all around
Hardrace rear camber arms
Wheels:
Konig Dekagrams 15x7.5 +35
Falken Azenis rt660 225/45/15 up front
Bridgestone re71r 205/50/15 in the rear (will be putting the same falkens in the rear, wanted to try a staggered setup and already had the bridgestones)
Brakes:
Stock GSR front and rear
Stoptech street performance pads
Valex racing ABS delete kit
Stainless lines
Misc:
Aem fuel rail
stock 240cc injectors (have grams 550's that will go in before dyno tune)
walbro 190
stock fuel regulator
-6 AN fuel feed with inline filter
AEM wideband gauge
Old 04-03-2021, 04:51 AM
  #86
90da4dr's Avatar
Dyno'd it yesterday 219whp and 165wtq. Still smokes a bit in decel.
Old 04-03-2021, 08:36 AM
  #87
Prudz_lude's Avatar
That's pretty decent power for the mods. Did you do a baseline?
Old 04-03-2021, 05:58 PM
  #88
90da4dr's Avatar
No there was no baseline, i got street tuned on oem 240cc injectors so i could break-in the motor. At the dyno right before the dyno tune i switched to 550cc injectors. The tuner started tuning immediately because the car was running rough.
Old 04-05-2021, 03:55 AM
  #89
90da4dr's Avatar
Yesterdays autocross. Car felt good. The mfactory diff made a huge difference. Can get on the gas much earlier.
Old 04-05-2021, 04:22 AM
  #90
danteisme's Avatar
I bet that felt good getting back out there with the new build.
Old 04-06-2021, 07:21 AM
  #91
Looking good man! I absolutely loved hitting the track after installing my LSD, its an awesome feeling.
Old 04-09-2021, 03:57 AM
  #92
90da4dr's Avatar
Yes it did, I had fun.
Old 04-09-2021, 03:58 AM
  #93
90da4dr's Avatar
Thanks, Its crazy how much the LSD changed the car.
Old 04-16-2021, 03:37 AM
  #94
90da4dr's Avatar
Dyno tune
Old 05-10-2021, 03:43 AM
  #95
90da4dr's Avatar
Car is starting to feel good. Still need to tune out a little oversteer but I got first in XSA during this event. Ordered some 225 falken rt660's for the rear. At the moment I'm running 225/45/15 falken rt660's in the front and 205/50/15 bridgestone re71r's in the rear. Not sure what that noise was at 23 seconds, it wasn't a cone.
Old 05-12-2021, 03:02 AM
  #96
Master Ninja
Eddie's Avatar
Miss reading build threads around here. Great job OP.
Old 05-13-2021, 04:47 AM
  #97
90da4dr's Avatar
Thanks
Old 05-18-2021, 10:05 AM
  #98
90da4dr's Avatar
Back at it again lol. I want to do a track day and the car smokes too much for my liking. Its fine for autocross but I didn't want to take it on track the way it was. I had smoking on startup, pressing the gas after idling for a while and on decel. I had a hard time installing valve seals twice now on new GSC valve guides. Spoke to the machine shop they told me to bring the head back and they will check it out. There was oil on top of every intake valve and 1 exhaust valve seal is leaking alot. Should have the head back by the end of the week. On the plus side, I'm getting faster at this lol. Only took me 2.5 hrs to get the head off and mostly disassembled. I dont have closer pics at the moment but the cylinder walls looked great. To note I only 1400 miles on this motor so far.
Old 05-23-2021, 09:16 AM
  #99
95_tegg's Avatar
Great build thread OP. Just picked up a 95 sedan and am now motivated to stop being lazy and start my build.
Old 06-21-2021, 04:05 AM
  #100
90da4dr's Avatar
Thanks man. Good luck with the build. I will be looking out for your thread.
Quick Reply: 95 integra gsr sedan - db8 build.
