1sicls build thread: DA integra
Old Jan 5, 2009 | 11:26 PM
1SicLS's Avatar
Default 1sicls build thread: DA integra
My plans so far will be boosted mild built ls. Suspension, redo all interior, and mod stock body some. I will post as i go along. But i am a college student with limited funds, My completion date will be at the most a month and a half from now. I go to school most of the time.
Here is how the car came, two gs rims, and two steal rims. It needs a shift linkage(the bushing gone). Some ebay coilovers, camber kit in front, and tan interior.
The car came with tan interior so i will be dying it all black, with rit dye and sem paint. So far here's whats ben done.
the ugly tan.
the black after
But here is a pic of trunk carpet. done (dont mind the spots its my camera lens need to clean it.)
Old Jan 6, 2009 | 12:31 PM
j_bizach's Avatar
Default Re: 1sicls build thread: DA integra
fiberglass and filler are gunna fail u need a plastic weld and plastic filler dont even bother using fiberglass or filler ud be better off using duck tape and bubble gum
Old Jan 6, 2009 | 12:42 PM
SPROCK3T's Avatar
i agree with Jordan, he knows his **** dude, but good luck.... cant wait for the pics
Old Jan 6, 2009 | 02:58 PM
1SicLS's Avatar
who makes the plastic filler? i go pic some up. and some plastic weld
Old Jan 6, 2009 | 03:20 PM
majinsoftware's Avatar
How Iv always done plastic welding is, On the out side face use some masking tape to hold it in the correct place. Then on the inside face take a low wattage soldering iron and melt it so it joins together.
Then pull the tape off the outside face and use lots of glue to seal up any gaps and make it stronger.
Then on the inside face put some duct tape over the melted joints just to give it bit more strength.
And finally a light sand to remove excess glue before painting.
Old Jan 6, 2009 | 03:59 PM
1SicLS's Avatar
yea i got it done i went to a body shop and ask how they would do it even bought the stuff the bumber will be done soon.
Old Jan 6, 2009 | 04:36 PM
hybrid90's Avatar
Take better pics dude cuz I just got a seizure trying to focus!
Good luck with your build!
Old Jan 13, 2009 | 05:51 PM
1SicLS's Avatar
I started shaving the trunk today.
An the bumper is almost done
As for the interior im done i just have to install it
I putting it in tonight then i will update
Old Jan 13, 2009 | 05:55 PM
1SicLS's Avatar
Next on the list is motor pull then mild tuck and shave. then paint.
Engine will be stock block with probe pistons, stock rods, micro polished crank, port and polished ls head then t3/t4 turbo kit, ys1 trans with stage 3 clutch.
Still undecided about suspension i need a good price with good performance.
Old Jan 13, 2009 | 06:35 PM
MD426's Avatar
Did you weld the holes on the hatch or just cover it with bondo? If you just used bondo then prepare yourself for it to crack and fall out eventually.
Old Jan 13, 2009 | 10:24 PM
1SicLS's Avatar
their welded here is a pic of the welder ground
nothing on my car is half *** i got to much time on my hands to not do it right
Old Jan 14, 2009 | 05:38 PM
j_bizach's Avatar
if your not gunna half *** anything id suggest that you go and buy a black interior cause all them plastic plannels that you painted are gunna be all scratched up and look like crap after a few months the problem with painting the pannels is that if theyve been treated with armoral ther pretty much junk went u go to paint them the paint is nvr gunna adhear properly plus that rattle can **** isnt gunna help. Buy a black interior
Old Jan 14, 2009 | 06:00 PM
egNYC's Avatar
I just picked up a 91 DA blk with tan interior. haha... also cant stand a tan interior and was going to dye the carpets. I pick up a black interior(most parts that are tan and rear seats was missing fronts) and goin to convert the interior to black.
Good luck on your project.
Old Jan 14, 2009 | 06:28 PM
1SicLS's Avatar
Well thanks for your opinion. But i will keep that in mind
Thanks and good luck with the interior. Keep me posted on your interior swap.
Old Jan 14, 2009 | 07:01 PM
MD426's Avatar
The panels should be fine, as long as you prepped it right, sand down and de-greased it with Acetone or something of that nature. Rust-Oleum sells a plastic primer that would help stabilize the paint.
Old Jan 14, 2009 | 07:49 PM
Danger's Avatar
SEM interior paint is awsome, prep it right and it will not fail. Good luck.
Old Jan 15, 2009 | 06:43 AM
1SicLS's Avatar
yea its sem paint and then clear coat on the pieces that will receive wear and tear. also i soaked them, sanded them and wiped them down with thinner.
also some more updates
now i'm pulling the motor and trans to do the engine bay.
Old Jan 15, 2009 | 07:12 AM
honda pride's Avatar
B.u.m.p.
Old Jan 15, 2009 | 07:48 AM
J.WOLFE~v1.0's Avatar
nice im a fan of shaving the trunk key whole. are you just goin 2 use a solinoid* to pop the trunk i guess?
Old Jan 15, 2009 | 03:06 PM
1SicLS's Avatar
i didn't shave the key hole yet that was the acura emblem hole. I am shaving the key hole though. it will be hooked thru my alarm
Might have some updates tomorrow but its 2 degrees here in ohio. my reedy heater can't compete
Old Feb 8, 2009 | 04:20 PM
1SicLS's Avatar
update.
The engine is out pistons and rods on the way, oem gaskets, timing belt, and ect. Turbo kit with super 70 turbo, and now im left with what to tune with.
started on the engine bay shave and wirer tuck. I have pics of progress and more to come so here it is
Old Feb 8, 2009 | 04:36 PM
sp00ledbseries's Avatar
hey man did the dye turn out pretty good or not. i have tan and i want black. and how did you die it spray bottle let it soak or what. looking good btw
Old Feb 8, 2009 | 04:39 PM
1SicLS's Avatar
on jack stands
wire tucking away (my friend mike)
no wires
Whole lot of wires. and dirty motor eww!
me pulling the motor (i look Hairy)
with the orange soda
Me pulling the motor and mike tucking
motor out
my girl working the hoist puling motor out
dash out thinking a brake line tuck dont know yet.
covering holes not to weld
abs delete
holes welded
loading pic of engine bay
Old Feb 8, 2009 | 04:46 PM
ALLxMOTOR EG's Avatar
Vietnamese!
get jdm 1 piece headlight
Old Feb 8, 2009 | 05:03 PM
1SicLS's Avatar
the trunk with one coat of primer.
the engine bay
