1998 Prelude Supercharged H23 Vtec
Old 11-29-2015, 10:37 PM
liveness2006's Avatar
Default 1998 Prelude Supercharged H23 Vtec
Hey everyone this is my Base 1998 prelude which is currently being built with a fully built Frankenstein H23 Vtec. This is posted on another forum and thought Id share on this site also.
Here is the lude a week before it went on vacation to the tuner
First day with my white lude after a 6 hour round trip drive (Silver lude was my other lude at the time)
Interior
Red carbon fiber dash accents
LED dome light
Sun visors from a 1997 prelude. (No yellow warning labels)
Momo shift ****
Exterior
Painted pure white
Carbon fiber hood
Side markers added to fenders
Clear leans on bumper
Halo headlights
x6 HIDs
55 watt Low beam 5000k
55 watt High beam 6000k
55 watt fog lights 6000k
Custom front LED blinkers
Suspension
Neoz wheels 17x7.5 +35 offset (Older set of wheels were a staggered set Privats fronts 17x7 and rears 17x8 both +40 offset)
Blox light weight lugs
Tein coilovers
Front and rear strut bar
Camber kit on the front
Drilled slotted breaks
Engine
H22 174whp
Aem intake
Skunk intake manifold
Torque dampener
Aftermarket header
High flow cat
2.5" exhaust
Muffler at the time was OBX exhaust. Current forgot will update...
Chipped ecu Chrome
slim radiator fans
I.C.E
Kenwood HD radio
Speakers aftermarket unkown
Amp Kenwood 1800 watt
Future mods
This is all purchased but not installed yet but SOON... the car is in the shop now.
Fully built supercharged Frankenstein H23 vtec
Jackson racing supercharger
Ported s tube to match throttle body
Larger jackshaft pulley
Ported H22 head
Sleeved H23 block
lower comp pistons... I have my reasons :wink:
Entire lower end balanced.
I think it was a f22 crank pulley? for more boost...
XTD light weight racing 10lbs but weighed it myself and it came out to 12lbs.
Aftermarket clutch can't rememeber at the moment
Adjustable cam gears
Thermal intake manifold gasket
70mm skunk throttle body
3" exhaust
AEM fuel rail
AEM adjustable fuel regulator
AEM intake
AEM alt and PS pulleys to help compensate for the larger crankpulley
AEM gauges
650cc RC injectors
H22 kaizen timing tensioner
H22 kaizen balance shaft eliminator kit
Traction bar
walbro fuel pump
MSD coil
Old 11-30-2015, 12:10 PM
Default Re: 1998 Prelude Supercharged H23 Vtec
As for suspension I only have a camber kit and my teins but I am hoping to get traction bar not sure what else I could get to help? Any ideas for upgrades on suspension wise?
Here are some pics of my suspension
Originally I had stock struts with lowering springs. Front lowering springs were Neuspeed and the rears didn't have any markings.
Here are some comparison shots
Rears
Fronts
Here is the weight of the new struts 12.8lbs . Couldn't find the pic of the older set but they weighted 15 to 16lbs. So there was a little improvement. :smile:
Story of these little guys found them on craigslist for $250. Sounds like it was a deal to me and drove 4 hours round trip. Worth it I think.
Another pic shows I had punch out the extra bolts for them to fit the prelude
Model numbers were dkh58- 115310 BB6 -f-98f
This is how low it was before the Teins.
Front wheel height before.
Front wheel height after.
Its a small difference but I no long have to drive sideways over speed bumps.
Also forgot I changed my rims 1 day before I dropped it off at the tuner. Found some pictures on my phone. Let me know how you guys like them? They are a different taste but I like them. Plus way easier to clean!
I have tons more pictures just let me know if its to much? I don't post often so kinda new to this. I am usually a lurker and dreamer on the forums but ever since my brain surgery I said screw it lets do it all. Jump first and ask later or I will never start my dreams.
Here are some more pictures of the wheels
Before
After
And a fun fact my mail lady said she "bumped" my mail box but looks like she ran it over.... it was in a wooden barrel lol
Weight of new wheels 21.2 lbs
Weight of old rims 19.8 lbs
Old 11-30-2015, 03:16 PM
Sanji
toyomatt84's Avatar
The new wheels are kind of a downgrade, to be honest. Hopefully you got them cheap.
Old 11-30-2015, 06:20 PM
Yeah my other wheels were nice I just hated cleaning those things plus I always seen similar wheels on every other car wanted a different look for a change. Picked them up for about $300 new in box. Seemed to be a good buy plus the wife liked them.
Here is the H23 engine and it sat in my spare room for almost a year sadly. I think I could hear cry once in awhile or maybe it was just me knowing that my lude could be a little faster one day. Which is finally coming around corner.
Not sure if you guys can see but in one of the cylinder there was an issue of an outline of the piston on the cylinder wall. Well that was the first step on the start of the entire build.
Took the engine and all the misc parts down to my tuner and they honed out the walls and balanced the lower end. I also had to get the block resurfaced due to who ever had this H23 last had a belt sander to level the deck, so that wasn't very smooth or a even flat surface. I also had a custom headgasket made to help make up the difference.
Here is the supercharger that a friend and I drove for 14 hours round trip to Idaho. Picked up this little guy for $1700. Came with a few extras AEM pulleys, some injectors, a head which I sold. It was only missing the alternator bracket, easy fix.
More to come if you guys want to see more?
Old 11-30-2015, 06:35 PM
Sanji
toyomatt84's Avatar
Sounds like a success then.
Old 12-01-2015, 10:52 AM
Here are some of the before and after shots of my carbon fiber hood. The carbon fiber hood was switched from my other prelude, but as seen it used to be very dull. Prepped it and my buddy clear coated it.
Before
After
Old 12-01-2015, 03:09 PM
conor97hx's Avatar
No such thing as too many pics man, nice lude
Old 12-01-2015, 05:03 PM
Thank you I have been taking pictures for years just encase I ever got around to posting this online. I always surfed around these forums being inspired and dreaming. I just hope to inspire other people just how I was inspired and dreamed
I thought this was a cool mod, here are the before and after sun visors. Haven't seen anyone do this yet and thought I would show it off. The yellow warning labeled visors are from my 1998 prelude and the gray cleaner look visors are from the my 1997 prelude.
Before
Drive side
Passenger
After
Driver
Passenger
Old 12-02-2015, 10:23 PM
Little update on whats going on...
I guess I was missing the tensioner bolt and bracket for the supercharger belt... but the tuner said he would modify it to work. I also was missing the IACV mounting plate but found a aftermarket one and ordered it from rosko racing. Also decided to not use my AEM intake which from I saw online its 2" and 3/4 and went with my Injen intake which was 3" in diameter. Not a crazy difference but I already got the bigger throttle body and port matched it to the S tube on the supercharger so though might as well. Sad note that it cost me $45 to ship it
I seriously can't wait to drive my car again. Before I drove it down to get built I found a taco bell receipt in my seat... it was a year ago that I last drove it to get a snack from taco bell. I am going crazy
Here are some pictures of the engine work done by the shop. You can see in the last picture of much the pistons stick out. Reason for the thicker head gasket.
Old 12-05-2015, 09:59 PM
So here is the link to the dyno of the prelude before the h23 swap. It dynoed at 175whp. You can see the crazy amount of smoke that its creating. Reason what started my journey to do this upgrade and swap. Hopefully I get to see how it compares too after the swap soon.
www.youtube.com/watch?v=UPStPGSMc_8&feature
Old 12-06-2015, 01:21 PM
Small update ordered a OEM accord f23 pulley since the other one I gave to the tuner was a cheap ebay one. The tuner said he had issues with them and advised to get an OEM pulley.
Also had the shop order a larger jackshaft pulley to increase the boost 3-4 psi more from Jim.
Also had the cat removed and replaced with a test pipe since my cat was almost clogged due to it smoking so much. Hoping it wont make to much more noise. I might later ad a high flow cat.
Here are some pictures of the parts that I have accumulated over time that I found on Craigslist for good deals.
Not sure if you can see but made by Zerg industries. Came with a trade.
AEM power steering and alternator pulley
AEM fuel regulator
AEM fuel rail.
RC injectors 650cc
Walbro fuel pump
MSD blaster coil
Old 12-08-2015, 11:47 AM
Small update:
Had three gauges, two AEM gauges and one new in box Auto meter gauge. Both AEM gauges didn't have any of the wiring or sensors. Turns out that crap is expensive.... $200+ to get those working.
So decided to go with the Auto meter boost gauge which had all of the wiring and sensor. Only thing is need another gauge for my duel pod. It was going to be a wide band but I am not going to be doing my own tuning anytime soon so I thought maybe intake air temp guage, since I am pushing 12-13 psi give or take.
Just thought I was ask you guys what other gauge would you guys run on this type of set up? Also to note I will get more gauges when I push this engine more but not enough money at the moment. No job kinda does that to you.
Also was going to have the valve cover painted with my favorite color but getting close to my limit for money on this build at the moment. It was ether have it painted or have it the valve cover taped for a catch can. So chose to go with function for now and come back to the cosmetic stuff later.
Here is the gauge pod from ebay not thing special
Small defect on the side, but it was like $10 so can't complain. I will upgrade later and sell this on craigslist for more
Here is that ECU that I just sold. Wanted to use it but already had a chipped ECU and thought the money from this would help finish the build
Here is the Injen intake that I sent down to the shop. Injen is 3" inches in diameter compared to the AEM 2.75" inches in diameter.
Dirty but gets the job done for now.
I will get some engine pictures up of what it looks like at the moment soon...
Old 12-08-2015, 11:29 PM
Hey everyone back from my wife's and I first anniversary! I thought my car would be done by now but the shop had some issues with my distributor. I am hoping for tomorrow that it will be done.
Here are some pictures of the engine. This was before they had AEM pulleys and larger crank pulley. Also before they modified the valve cover.
You can see the adjustable came gears
Closer shot of the supercharger and Skunk2 throttle body.
Old 12-10-2015, 08:04 PM
Small update and some pictures.
Had to modify the alternator AEM pulley to fit properly.
Old 12-12-2015, 09:06 PM
Prudz_lude's Avatar
In on this build! What header are you planning on going with?
Old 12-14-2015, 10:21 PM
Steve at Heart
Bently_Coop's Avatar
Nice build. H23Vtec + JR SC is a win.
I do like the original wheels better though.
Old 12-17-2015, 02:12 PM
At the moment I am using the header that came with the car. I am not sure what brand it is some aftermarket header.
Thank you As for the wheels I am hoping to save up money for some 8" wide wheels later on. I just wanted a unique look for now.
So for the first dyno pull the supercharger was pushing 15psi not sure why... Any ideas? 6psi stock I think the accord adds another 3psi and the jackshaft 3-4psi. Correct me if I am wrong. :confused:
Decide to back down the psi for now. Going back to the original crank pulley.
Also found out that the one of the bearings needed to be replaced so after all of that the car just needs to be dynode and tuned. Hopefully nothing else goes wrong.
On a better note more pictures!
Front end was in an accident from the last owner. Had some issues with the new radiator due to the front being bent a little.
Old 12-20-2015, 06:51 AM
Here are more pictures!!!
Here are the CNC pulleys to replace the plastic ones, and the extra pulley up top to help the belt slippage.
You can see all the plastic pulleys replaced with the aluminium pulleys.
Old 12-20-2015, 12:58 PM
Skirt's Avatar
In reply to the coilovers, ive heard f&f2s are awesome along with BCRs. Never had either but if you do a quick google search many swear by them
Old 12-21-2015, 09:57 AM
StreetLethaleg6's Avatar
nice prelude, and def gonna be fun once its supercharged. like many have said before, i strongly dislike the wheels but to each is own. good luck with the build.
Old 12-21-2015, 10:21 AM
Raf99's Avatar
Nice. This sure will be a tight squeeze, especially on the drivers side. No more front strut bar anyways....
Old 12-28-2015, 08:36 AM
Little_Nolan's Avatar
This is sweet! I am in for the next update.
Old 12-29-2015, 11:46 PM
Well sadly I don't have much for an update. Last I talked to the tuner they finally got the belt to stop slipping. Also not much work was done due to the holidays. So they were aiming for around the first of the year in January to have it finished.
Just to keep this active I added the dyno graph of the what my original H22 dynode at.
Stats of H22 at the time just incase anyone was wondering.
H22 engine
Aem intake
Skunk cams
After market header with 2.5" OBX cat back system. which was really loud inside and out...
Chipped ecu
Light weight fly wheel
Old 01-23-2016, 03:30 PM
Quick update!!! I am currently on my way to the tuner to pick up the prelude‼ I will get some pictures soon and the dyno graph and hopefully the dyno video.
Old 01-24-2016, 12:42 AM
Prudz_lude's Avatar
Sweet! Post up vids, pics, and the graph!
Quick Reply: 1998 Prelude Supercharged H23 Vtec
