Uberdata?
From: Your really lame if you dock my points, WA, 98033
is anyone in here familiar with Uberdata? i know some people using it on thier turbo setups. i hear its as good as hondata if not better and way cheaper. anyone have any direct expierince with it on Allmotor apps?
if you dont get any info on the this the next couple weeks, IM me. i am in the process of using uberdata to tune my ls/vtec but i am still in need of the 74hc373 chip.. suprisingly hard to find
I have Uberdata it's awesome, all motor and turbo. Go to http://www.homemadeturbo.com, the engine management FAQ has lots of info on it. You can get those IC chips there too. Good luck
k so i downloaded the software... im messing around with the base p30 maps, and i was wondering if anyone has any good bins for a b16a with i/h/e. also what are some of you guys using to burn chips with?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg »</TD></TR><TR><TD CLASS="quote">http://www.pgm-efi.org or something like that. best place youll find info.</TD></TR></TABLE>
i clicked that link but it didnt work but i think i found the link you were refering to..
http://www.pgmfi.org/
For future refernce.
also found this site. which is easier to navigate through then the other one.
http://www.nitroburn.com/pgmfiwiki/index.php
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 71 mgb »</TD></TR><TR><TD CLASS="quote">if you dont get any info on the this the next couple weeks, IM me. i am in the process of using uberdata to tune my ls/vtec but i am still in need of the 74hc373 chip.. suprisingly hard to find
You can find the octal buffer at a place like Digikey (<U>www.digikey.com</U> from 45 cents or so. All the parts should be interchangeable so all you have to do is a search for 74HC373 ( you're after the 20 pin DIP package).
Here are some number for your -> MM74HC373N, SN74HC373N, TC74HC373AP.
These are the manufacturer's part numbers for their 74HC373. MM is from Fairchild, SN is from Texas Instruments, and TC is the Toshiba offering.
If you enter one of them into a part number search at you should get a listing for the 74HC373 by that specific manufacturer in a 20 pin DIP package.
Hope that clears it up a little for you.
https://honda-tech.com/zerothread?id=694581
This is the most recent Uberdata thread, to my knowledge. Read up!
I'm running Uberdata untuned on my turbo LS and I'm impressed... Though I don't anything to compare with. The car runs like stock, then flies when boost hits. At ~$100 complete, you're looking at a deal over Hondata's $400.
