Rocket Motorsports M25
Old 12-12-2011, 10:10 AM
soxle's Avatar
Default Rocket Motorsports M25
Hello,
it's very difficult to find info on those cams.
what are the BTDC, ABDC, BBDC, ATDC?
and if possible the difference of lobe in X and standard cams?
or just a pic with cam profile like this for example: the endyn cam
thanx,
I have only found that:
INTAKE lift - 12.1 mm, duration 270 @ 1mm
EXHAUST lift - 12.1 mm, duration 270 @ 1mm
I don't want the specs of the M25E cams. lift too agressive for my set-up: valves too small.
if you know a set-up with those cams or a dynosheet, I will be happy too!
Old 12-12-2011, 07:32 PM
koczeka's Avatar
Default Re: Rocket Motorsports M25
I had them, I loved them. Way bigger than the Pro3s. Made 40hp more in the midrande and 16hp more on top in my big 2l. I suggest to use it only in very serious setup over 2l.
edit: degree them to 100, 109 lobe center.
Old 12-13-2011, 07:35 AM
Rosko's Avatar
Originally Posted by soxle
Hello,
thanx,
I had a hard time getting the info from Rocket himself back when I had a pair of M24x's, makes it difficult to degree without those specs!
Old 12-13-2011, 08:09 AM
A Digital Frontier
dirtyharryhatch's Avatar
jesusssssss
Old 12-13-2011, 09:02 AM
Fink29's Avatar
Op, Do you have the rm m25's already? If so I can get you the specs.
Old 12-13-2011, 09:19 AM
Fink29's Avatar
THE GREAT ONE has emailed me the spec. Op, Pm me when you get a chance.
Old 12-13-2011, 10:37 AM
HellaFab's Avatar
does rocket motorsports even have a website? i have tried looking them up before...
Old 12-13-2011, 10:48 AM
Fink29's Avatar
No rocket motorsports as a company Is closed. You can still get some of his products though select dealers on the web on this website.
Old 12-14-2011, 12:51 PM
97mm_EH3's Avatar
How much lift did they have over the Pro3's?How much more duration @.050 and .100 than the Pro'S? Was the 40 more BHP on the primarys ore Vtec lobes?
Old 12-14-2011, 09:09 PM
koczeka's Avatar
I replaced tuner3s with m25 back then. 40hp was @6000, right before VTEC. Reason is the Tuner3s has basically stock primarys. Lift is not important over 12mm IMO, duration rules.
Own, not NASA accurate measurements:
Tuner3
12mm/11.5mm 256°/250°@1mm 88°/80°@10mm
Pro3
12.24mm/11.85mm 260°/268°@1mm 100°/94°@10mm
m25
12mm/12mm 275°/273°@1mm 100°/100°@10mm
Old 12-14-2011, 09:17 PM
A Digital Frontier
night and day difference before vtec huh?
Old 12-15-2011, 02:27 PM
97mm_EH3's Avatar
Tuner3
Pro3
m25
So, your BHP comparisons are to the 1996 tuner 3's/ Not Pro 3's plus your numbers are wrong. Thanks for the info. Pro 2's are larger than the 3 numbers you gave.
Old 12-15-2011, 02:56 PM
Fink29's Avatar
All Duration @ .050
M24xx Intake .472/262 Exhaust .472/262
M25xx Intake .472/270 Exhaust .472/270
S.Cam Intake .462/276 Exhaust .462/276
Pro2 Intake .493/258 Exhaust .458/265
Pro3 Intake .500/270 Exhaust .470/273
Lets all remember that cams are more than lift and duration.
Old 12-15-2011, 08:50 PM
koczeka's Avatar
I do not care what do U believe or not.
Pro2
12.16mm/11.49mm 250°/257°@1mm
Old 12-15-2011, 09:59 PM
Fink29's Avatar
Well lets just take look at the valve events for the Pro2 cams.
Intake
Opening:31° BTDC
Peak Lift: 99° ATDC
Closing: 46° ABDC
Exhaust:
Opening: 58° BBDC
Peak Lift: 106° BTDC
Closing:25° ATDC
Intake Duration: 31+180+46 = 257
Exhaust Duration: 58+180+25 = 263
Duration at .050 as listed by Skunk2
Intake: 258
Exhaust: 265
Well that's just my take on things. I personally go by valve events because I didnt have a means to check on the engine.
FYI if you check duration by valve events with RM cams they are dead on to what they are advertised as, Unlike most cam manufacturers.
Old 12-15-2011, 10:04 PM
allmotorpackage's Avatar
i think what koczeka is trying to say : is that he personally measured alot of cams including the whole skunk2 lineup , and they are far from what skunk2 advertise it to be ..
its interesting that alot of people make good power with the Pro3 , and they SEEM to be a pretty big cam , but if koczeka's measuring is correct , they are not too scary
Old 12-15-2011, 11:26 PM
Fink29's Avatar
I know he has. I was just adding to the thread not disputing his findings. The problem is there is no set standard on how cams are measure and advertised. Some companies advertise at .050", some at 1mm (0.039") and then comes S2 and they advertise at 0.004". Which would make their (S2) seems ALOT bigger than others.
Old 12-16-2011, 07:14 AM
koczeka's Avatar
Yes, exactly, thank U!
We measure them the same way, I do not care what anybody else think... TODAs, BC, OEM and a few others like m25 match the "advertised" spec, skunks never.
I now, a few numbers does not mean too much (sorry I have no tool yet to draw full graphs), but when U see 2 cams with max lift, 1mm AND 10mm duration numbers... U can have a basic idea.
This thread is about m25, I had them, I loved them, I know its way bigger then anything else I have hold in my hands (including P3).
Old 12-16-2011, 08:34 AM
eDm cRxXx's Avatar
This can't be correct? maybe som really old cams?
I seriously doubt he used the exact same lift and duration on intake and exhaust.
Old 12-16-2011, 08:40 AM
soxle's Avatar
thank you everybody.
I will make you angry: you have given me want to open a new topic on SuperCam! : lol:
Old 12-16-2011, 10:10 AM
acura_b18c1's Avatar
All Duration @ .050
y is it that the rocket lineup's lift never change ? in the supercams case , it even went lower?
all skunk2 and other cam companies seem to have more lift than rocket's . any reasoning to this ?
Old 12-16-2011, 11:07 AM
DDTECH's Avatar
Duration is bigger.. also the ramp speed / angle are all different as well, just because a cam doesn't have alot of lift doesn't mean its not a SERIOUS valvelift profile.
Old 12-16-2011, 11:17 AM
eDm cRxXx's Avatar
Quote from ALL MOTOR (dd-tech/derek) in the supercam thread (https://honda-tech.com/forums/showth...hp?t=2960385):
Originally Posted by ALL MOTOR
duration @ .050
buddyclub4 257 259
m22 260 264
pro2 260 267
skunk2 tuner 3's 260 269
buddyclub5 262 271
m24 269 279
pro3 269 275
m25 275 270
Supercams 278 277
Bigger isn't always better.. there's more to making power with cams then lift and duration. Those measurements are what my grinder took from his machine. Those are also on a profile sheet i recieved from DonF and rocket.
the lift is roughly .520 something int exh is like .480ish or something like that.. i dont have the exact specs infront but its something around there give or take. (supercams this is)
hope it's OK that i quoted this.
Old 12-16-2011, 12:09 PM
Fink29's Avatar
I get my information from the source so if they are wrong than Rocket himself sent me the wrong information. WHICH I HIGHLY HIGHLY DOUBT.
Do you have any experiance with RM Cams?
Alot of smart people think that lift over 12 mm isnt all that hott. Even when Brad/Rlz had cams out they didnt have much lift but had tons of duration.
Old 12-16-2011, 12:43 PM
yea I'm not bashing anybody's products. jus curious. if a race port flows hypothetically , 290 cfm at .472 lift , and then 300 cfm at .500 lift , wouldnt u want to increase the lift to .500 instead of leaving it at .472 ? ( comparing the m25 and pro3 from above )
Quick Reply: Rocket Motorsports M25
