Post you poor man type r set ups
Definetly not a "poor man" r setup but here ya go
b18c1 block
polished balanced gsr crank
polished shot peened gsr rods with arp bolts
modified pct pistons all pistons balanced within +/- 1 gram of each other
modified oil pump
act lightweight flywheel
act 6puck clutch hd pressure plate
complete rotating assembly balanced
b16 head full port and polish by chad barber@ctr dynosports
custom made bronze valve guides by kms engines
custom made springs and retainers by kms engines
supertech flat face nitrate coated valves
skunk2 stage2 cams
ported polished victor-x intake manifold by chad barber@ctr dynosports
70mm str throttle body
arp main studs and head studs
s4c tranny (2000 civic si)
msd sci-l ignition with msd hvc coil
ngk power cables and spoon spark plugs
rage performance big tube tri-y header
to many other mods to list....you get the idea
custom modded p30 ecu tuned by me running crome gold.
new 3" kteller exhaust to go on tommorow and retuned.
b18c1 block
modified oil pump
skunk2 stage2 cams
b18c jdm gsr block
-b18c1 crank
-jdm itr piston pressed on gsr rods
99 b16a1 head
-itr internal and cams
Gsr tranny
ACT clutch
12 lbs. ACT flywheel
ACT pressure plate
ARP head studs
-b18c1 crank
99 b16a1 head
Gsr tranny
ACT clutch
ACT pressure plate
ARP head studs
OK, me and my buddy just got done building a poor-man type r but after driving it the motor seem to feel like there is a major power loss on top end. I've check the compression but it seems like I'm not getting the right psi for the piston that I've put in. Am I leaking compression anywhere? or did i not torque the head down right? A torque spec would also help just in case that i didn't torque down the head right. Any info would help out a newbie like me thank you. Here is a list of the build.
-B18C1 bottom block
-B18C1 Crank
-B16?? cylinder head (stock)
-Jdm ITR Piston (standard oem size)
-Stock Gsr injector
-Gsr timing belt
-B18C1 bottom block
-B18C1 Crank
-Stock Gsr injector
-Gsr timing belt
You're timing is off, otherwise your not keeping the compression in the combustion chamber. Valves, rings, head gasket. Good Luck!
92LSVTEC
Feb 10, 2007 10:03 AM
R.and.Y
Nov 6, 2006 09:27 AM
SiKDeLSoL
Jan 5, 2003 03:27 PM
