The Plagued Belt Squeal
Old 05-06-2011, 02:13 PM
Ashe 3.0's Avatar
Default The Plagued Belt Squeal
I'm sure many of you have been plagued with the squeal that starts when your car turns on, sometimes even when running, and seems to happen less when the engine is warmed up.
My Ride: A 1997 Civic EK with a stock 1.6L D-series.
A few months ago I replaced my alternator and I had to disassembly the engine head to reach down there. Putting the belts back on, I must have missed something.
Most of you are thinking, "Adjust the belt tensioner". Nope, tried that. Loosened it, tightened it... Eventually I put it back to where the rust lines on the bolt stopped - back to stock position.
Also note, I ripped out my power steering so I have 2 belts. The other day I took a wrench and banged on the first belt, it was stiff and tight. The second belt (alternator) was loose and saggy.
Looking at my alternator, perhaps it fell out of place? It LOOKS like there's a little hook that the alternator should be hooking on and it's not.
Does anyone know if this would fix my issue? How can I tighten that belt?!
And after, should I put a belt conditioner or lube on it?
Help! At this rate, I'm never gonna get laid again!
Ashe
Old 05-06-2011, 02:30 PM
94VTEC2TONE's Avatar
Default Re: The Plagued Belt Squeal
tighten your alternator by either using a prybar or 2 wrenches. dont need belt conditionor or lube ive never used that crap
Old 05-06-2011, 03:01 PM
96dxB16's Avatar
make sure the lower bolt is still there on the alt
Old 05-06-2011, 03:33 PM
bambam's Avatar
You disassembled the head to change out an alternator? Good lord man. There is no directionr for the alternator. Just use a pry bar as stated and shove it back. Tighten the nut on the upper bolt while doing this. May be easier with a friend to assist. Belt should have about a 1/2 inch of deflection when tighten properly. This means 1/4 inch in either direction.
Old 05-06-2011, 05:24 PM
Str8EJ's Avatar
So, how old is this belt?
Sounds like you need a new one.
Old 05-06-2011, 06:00 PM
Ashe 3.0's Avatar
Adjustment and new belt sounds about right. I had a new one too and I either returned it with the old alternator, or I gave it away/: That means I've gotta wait a week for $$ lol.
I'll take some pics tomorrow and keep you guys updated. Thanks for the tips!
Old 05-11-2011, 08:18 PM
Ashe 3.0's Avatar
Pried the alternator back and retightened the allen screw. It fixed it mostly...
But it still squeals on occasion. Gonna try replacing the belt this weekend.
M.D. CIVIC
10
02-23-2010 06:47 PM
el1cuban
04-18-2009 10:10 AM
KOALA YUMMIES
09-23-2005 09:05 AM
519[H]Si
05-25-2004 09:25 PM
JDM R98
07-05-2001 03:27 PM
Quick Reply: The Plagued Belt Squeal
