No spark, whats the problem please help!
Old Jan 7, 2009 | 08:50 PM
Dave_Dc2's Avatar
Default No spark, whats the problem please help!
there is no spark reaching the plug wires. tried 3 different distributors, tried many different ecu's..wiring is good and all grounds are grounded, fuel is going in the engine..but theres no spark? thank you
Old Jan 7, 2009 | 09:02 PM
onepoint6i's Avatar
Default Re: No spark, whats the problem please help!
what car?, what engine?, what ecu?
what are you checking spark with?
Old Jan 7, 2009 | 09:24 PM
Dave_Dc2's Avatar
integra gsr, ob2 to obd1 conversion its a chipped p28 with a jumper harness ofcourse.. i ground the plug wire to check for spark but it only sparks once and goes away as i crank the car..
Old Jan 7, 2009 | 09:59 PM
TheHondaGuy's Avatar
check new dizzy/pull off cap to see if they gave you a rotor. (happened to me before)
Old Jan 7, 2009 | 10:08 PM
Dave_Dc2's Avatar
ya the new distributor is complete..and its in proper working order..
Old Jan 7, 2009 | 10:25 PM
jdm602's Avatar
what kinda harness is it?
Old Jan 8, 2009 | 06:16 AM
Dave_Dc2's Avatar
It's the stock ob2b 2001 integra gsr harness
Old Jan 8, 2009 | 06:44 AM
FST GSR 1's Avatar
Check coil resistance yet?
Old Jan 8, 2009 | 07:23 AM
Dave_Dc2's Avatar
how do u check that
Old Jan 8, 2009 | 08:24 AM
Str8EJ's Avatar
you'll need a multi-meter to check for resistance between a couple of contact points, fairly straightforward once you extract the coil.
good luck!
Old Jan 8, 2009 | 10:10 AM
jdm602's Avatar
or you can just swap the dizzy with a known good one.
Old Jan 8, 2009 | 10:17 AM
onepoint6i's Avatar
Do you guys even read the original post?? He's tried 3 different distributors already..assuming all 3 coils and ignitors aren't bad this is a wireing problem..
Are you sticking screw driver or something metal inside the plugwire then grounding it??
Buy yourself a spark checker tool at auto zone it's more consistent..if still no spark..
check fuses double check the jumper harness wires and pin fits.. make sure you have power at the distributor....get yourself an ETM check continuity from the ecm to the distributor plug etc etc..
Old Jan 8, 2009 | 10:34 AM
FST GSR 1's Avatar
Maybe I am trying to help him really find the problem and learn something in the process? Coil would be the first thing to check, stop swaping unknown condition parts...one may have a weak ignitor, the other may have a bad coil, one may be missing an ignitor...who the **** knows, I can't see them...Hell maybe he has an external coil, he doesn't specify...So F'n relax post count hero.
Old Jan 8, 2009 | 11:11 AM
ruffrhyder's Avatar
Are you sure your timing belt is good? My buddies civic had the same problem, we swapped dizzy's, ecu's etc. Turned out his timing belt was toast and cam wasn't spinning.
Old Jan 8, 2009 | 12:24 PM
jdm602's Avatar
eh i forgot he tried the other dizzys, i was going of the previous poster on that one. lol o well.
might try a different jumper harness. that was my problem. was a bitch trying to figure out and fix the things that WERENT wrong with the car, haha. then i thought hmm, maybe its the jumper harness and sure enough it was.
Old Jan 8, 2009 | 02:09 PM
onepoint6i's Avatar
This is not a school dip ****, you wanna learn something go to school...dont come in here giving your stupid assumptions of crap that aren't helping anyone ***gsr fucktard..
Old Jan 9, 2009 | 09:17 AM
Str8EJ's Avatar
perhaps you should re-read the original post.
like we learned as kids, assuming makes an "***" out of "u" and...well, basically just you.
i really hope the majority of your posts were better conceived than this one.
good luck to you in future endeavors.
Old Jan 9, 2009 | 01:53 PM
JDM JEFFREY's Avatar
try putting in the obd2 ecu with no jumper harness and see if that works?
Old Jan 9, 2009 | 02:38 PM
onepoint6i's Avatar
How does this statement help the ot?
What does my post count have ANYTHING to do with this conversation? Don't be mad at my post count, not like theres a reason to be..It doesnt mean anything..it's just a number son..get over it..
Im not "assuming" edit...If the OP had any idea of how to diag a no spark condition he wouldn't have asked this question correct?
If you have
1: a properly operating coil
2: a properly operating ignitor
3: a properly operating ecu
4: a properly operating crank/cam sensor
theres a wiring problem
so If you dont have anything to say about the OT, have a nice day..
Old Jan 9, 2009 | 04:37 PM
Str8EJ's Avatar
Im not "assuming" jack off...If the OP had any idea of how to diag a no spark condition he wouldn't have asked this question correct?
funny, you literally used the word 'assuming' in your post. either way, the name calling is unnecessary.
to the OP, apologize for my involvement in this meaningless side-bar. per your question regarding the process for checking resistance at the coil, it's not a biggie. sounds worse than it really is.
1.6's post is somewhat relevant, try to work through all ignition related components one at a time. until you can verify that they're all operating properly, it's a shot in the dark. i wouldn't recommend replacing parts blindly until you find something suspect.
if available to you, review the factory service manual for guidance.
g/l.
Old Jan 10, 2009 | 01:19 PM
onepoint6i's Avatar
CivicCpeEX
Jul 11, 2010 07:59 PM
tree fingers
Aug 4, 2009 11:58 AM
hondallday
25
Jan 19, 2009 01:53 PM
Dave_Dc2
Jan 16, 2009 03:05 AM
thrty8street
15
Apr 18, 2006 02:46 PM
