? D16Y8- Specs.
Old 12-09-2003, 01:38 PM
Civic-Ex-98's Avatar
Default ? D16Y8- Specs.
I would like to know if anybody has specs on the y8 motor out of a 98 ex. I want to built up a sleeper D. I know the Hp, but I don't know:
- torque
- compression
- alt. heads that might give better power curves
- fuel rails
- intakes
- ex. manifolds
- good ex, systems
If you have a D let me know what you are running.
Old 12-09-2003, 04:01 PM
Rocket's Avatar
Default Re: ? D16Y8- Specs. (Civic-Ex-98)
MAX_CFM has some thoughts about Z6 head vs. the Y8 head.
Throw a good IM and cam and header on it with hondata and your 80% there.
Old 12-09-2003, 06:04 PM
95slowmattic's Avatar
my roommate has a 97 civic who has done a lot with it. the hp slould be at like 130 at the crank and 90 something for torque. single cams suck for torque. but they have a junk load of top end. compression you should be around 10.0:1 or so. that or just above. keep the stock head on there. its way better than the z6 head. your motor creates more torque than the z6 engine. aem makes a good fuel rail, i don't know who else though. don't use the v2 aem intake on your car. i've heard bad things about those. the normally designed one is nice though. if you want carb leagal headers go for dc, but if you want something beyond sissy girly everybody else performance, go with greddy, or something thats not smogable. whatever exhaust you want, as long as you get your desired sound. i know the apex n1 is popular and used a lot. i like the sound of it. good luck.
Old 12-10-2003, 08:31 AM
civic_6991's Avatar
Go to http://www.clubcivic.com
It has specs on all civic motors
Old 12-13-2003, 12:45 AM
Default Re: ? D16Y8- Specs. (civic_6991)
thanks, site had a lot of info.
Old 12-15-2010, 06:06 PM
scotch1020's Avatar
got a ques??? i have stock d16z6 and have opportunity for a d16y8 head and intake.... is it worth getting and can i do that..... i know i can put the y8 intake on the z6 and it adds hp but what about the whole head???
StuckInTexas
08-09-2014 08:11 PM
thecruzs2007@yahoo.com
10
08-24-2009 07:55 AM
Quick Reply: ? D16Y8- Specs.
