my b18c build
my b18c build
Ok so i would like to hear some feed back about my build before it goes in and tuned so here it is....
b18c1 block 81.5mm
b18c1 crank reconditioned
eagle h beam rods
wiseco 13.2:1 to 14:1 pistons
pnp p72 head and milled just a lil to clean it up
5 angle valve job
bronze valve guides
ferrea 6000 valves
skunk2 pro3s
pro series valve train
blox ported intake mani
68 to 70mm omni tb
aem fuel rail
450cc injectors
hytech tri-y big tube replica
b16 tranny
act clutch kit
That should do it.....my whp goal is around 240whp my tuner says it should but you never no
b18c1 block 81.5mm
eagle h beam rods
5 angle valve job
bronze valve guides
ferrea 6000 valves
skunk2 pro3s
68 to 70mm omni tb
aem fuel rail
450cc injectors
b16 tranny
act clutch kit
Re: my b18c build
Very similar to my current gsr build. Except I'm at 84mm with itb's and Pro 2 cams. Your power goal should be made with a good tune. Only thing I would change with your setup is the Blox intake mani for a Victor X. Than's just my .02.
Re: my b18c build
Yea I woulbd be going with itbs and sleeved block if i had it this year , but ill be happy with what it is as for now....
Re: my b18c build
my whp goal will be closely met...ive researched on here and other sites and there are a couple 1.8l making in the 220-236 with less head work and smaller cams , bu thanks for all the opinions
Re: my b18c build
i dont think you'll squeeze anymore outta it buddy.. but keep the faith...
Re: my b18c build
im hoping for 200-210 on mines but less compression 1.8 12.5cr custom bisi header and toyota itbs...on buddy club spec 4 cams...also cnc ported RLZ head...i dont see 240whp out of a 1.8l but if u get there theres hope for me also...
Re: my b18c build
Is anyone going to let him know that a stock port P72 won't flow enough to get to 240whp. Your head is going to need at least 270-285cfm to get anywhere near 240whp.
Or how about the Blox manifold that has the intake runners at the wrong angle for a P72 head. The plenum on that manifold is going to be way to small for your target WHP. You will need at least a Px or even better a Vx manifold.
Then again a very generous Dynopack might get you to 240whp.
Re: my b18c build
If you look at similar setups to his on there. They are making roughly 200-215hp. If the stroke was increased with the LS crank and rods. I think he could at least see 230hp.
Re: my b18c build
Re: my b18c build
thanks for the input but if you had read what i stated my head is fully ported and polished and my whp goal is high but my tuner and i dint see me making anything under 220 i have the motor to do this the only thing thats would be a hold back is that its 81.5mm but displacement isnt everything a good tuner knows that.....and as for the intake its fully ported n polished also and the blox flows the same as a factory itr
All Motor Mentor
1 Post
Re: my b18c build
If a stock ported pr3 head can get over 240hp I don't see how a gsr couldn't...Don't people actually get on evans-tuning and look at his dyno database? There is an 85mm stock stroke gsr on there making 242hp!!!! Granted it is on an 85mm bore so that helps out with the displacement.
85mm bore vs 81 is a big difference. I know first hand how tough it is to break the 200whp mark on a 1.8L and this build WILL come up short. There's not a tuner out there that can change facts....maybe a magician.
Re: my b18c build
Sounds like a Good build. your 240 MIGHT not be met. But I wouldnt be suprised if you dont make atleast 200-215.
This is coming from someone that HAS done it. Not just someone that Reads about builds.
So its on you. Do the build right, Get a great tune for it. Let us know what you make.
With all the mods and machine work you listed, I have Faith in it.
Re: my b18c build
Re: my b18c build
I agree with you on getting a px but ima get itbs later and the blox is good enough and its what i got
Re: my b18c build
240+hp on stock port pr3 head with a performance VALVE JOB, on a well built 2L motor, maybe. On a 1.8L....not likely.
All Motor Mentor
1 Post
Re: my b18c build
When I said it would fall short, I wasn't talking 200whp, I was talking your goal of 240whp. I'm thinking you'll be lucky to hit 220whp with that build but regardless of what your dyno spits out as a number, I'm thinking your trap speeds will indicate a 215-220whp actual power output at best. I'm only saying that honestly. I'd love to be wrong about this and give you credit for a great build if you reach your goals.
Re: my b18c build
Same vote here I would go 84mm. I have the same pistons as you except in 84mm. With your gsr head you would have somewhere around 13.4-13.7:1 compression without taking any material off the block or head. With your supporting mods with the ported head I think you would easily crack your power goal.
