my b18c build
Ok so i would like to hear some feed back about my build before it goes in and tuned so here it is....
b18c1 block 81.5mm b18c1 crank reconditioned eagle h beam rods wiseco 13.2:1 to 14:1 pistons pnp p72 head and milled just a lil to clean it up 5 angle valve job bronze valve guides ferrea 6000 valves skunk2 pro3s pro series valve train blox ported intake mani 68 to 70mm omni tb aem fuel rail 450cc injectors hytech tri-y big tube replica b16 tranny act clutch kit That should do it.....my whp goal is around 240whp my tuner says it should but you never no |
Re: my b18c build
240whp sounds like alot from a 1.8l...225-230 is the most ive seen..but good luck
Re: my b18c build
there are a few 1.8l builds making 230+ with half the headwork and smaller cams
Re: my b18c build
Very similar to my current gsr build. Except I'm at 84mm with itb's and Pro 2 cams. Your power goal should be made with a good tune. Only thing I would change with your setup is the Blox intake mani for a Victor X. Than's just my .02.
Re: my b18c build
Originally Posted by hatchn1.9
(Post 45113990)
Re: my b18c build
(Post 45113990)
Re: my b18c build
Originally Posted by DA93teg87
(Post 45119089)
Re: my b18c build
my whp goal will be closely met...ive researched on here and other sites and there are a couple 1.8l making in the 220-236 with less head work and smaller cams , bu thanks for all the opinions
Re: my b18c build
(Post 45124344)
i dont think you'll squeeze anymore outta it buddy.. but keep the faith... |
Re: my b18c build
im hoping for 200-210 on mines but less compression 1.8 12.5cr custom bisi header and toyota itbs...on buddy club spec 4 cams...also cnc ported RLZ head...i dont see 240whp out of a 1.8l but if u get there theres hope for me also...
Re: my b18c build
Is anyone going to let him know that a stock port P72 won't flow enough to get to 240whp. Your head is going to need at least 270-285cfm to get anywhere near 240whp.
Or how about the Blox manifold that has the intake runners at the wrong angle for a P72 head. The plenum on that manifold is going to be way to small for your target WHP. You will need at least a Px or even better a Vx manifold. Then again a very generous Dynopack might get you to 240whp. |
Re: my b18c build
Originally Posted by OH_1fstgsr
(Post 45127160)
Or how about the Blox manifold that has the intake runners at the wrong angle for a P72 head. The plenum on that manifold is going to be way to small for your target WHP. You will need at least a Px or even better a Vx manifold. Then again a very generous Dynopack might get you to 240whp. If you look at similar setups to his on there. They are making roughly 200-215hp. If the stroke was increased with the LS crank and rods. I think he could at least see 230hp. |
Re: my b18c build
(Post 45127160)
Re: my b18c build
bumpssssssssssssssssssssssssssssssssss
Re: my b18c build
(Post 45129807)
thanks for the input but if you had read what i stated my head is fully ported and polished and my whp goal is high but my tuner and i dint see me making anything under 220 i have the motor to do this the only thing thats would be a hold back is that its 81.5mm but displacement isnt everything a good tuner knows that.....and as for the intake its fully ported n polished also and the blox flows the same as a factory itr
Re: my b18c build
Originally Posted by prjoker81
(Post 45129841)
:crook: |
Re: my b18c build
(Post 45127800)
If a stock ported pr3 head can get over 240hp I don't see how a gsr couldn't...Don't people actually get on evans-tuning and look at his dyno database? There is an 85mm stock stroke gsr on there making 242hp!!!! Granted it is on an 85mm bore so that helps out with the displacement.
If you look at similar setups to his on there. They are making roughly 200-215hp. If the stroke was increased with the LS crank and rods. I think he could at least see 230hp. 85mm bore vs 81 is a big difference. I know first hand how tough it is to break the 200whp mark on a 1.8L and this build WILL come up short. There's not a tuner out there that can change facts....maybe a magician. |
Re: my b18c build
if you went with an ls crank and rod combo the extra 2mm stroke will help more than the 87mm gsr crank...
Re: my b18c build
Sounds like a Good build. your 240 MIGHT not be met. But I wouldnt be suprised if you dont make atleast 200-215.
This is coming from someone that HAS done it. Not just someone that Reads about builds. So its on you. Do the build right, Get a great tune for it. Let us know what you make. With all the mods and machine work you listed, I have Faith in it. |
Re: my b18c build
Originally Posted by M&R BUILDS
(Post 45130572)
Re: my b18c build
(Post 45130079)
I may have missed the pnp on you list my bad. But I stand behind the manifold point. You will come up short and need to go with at least the Px. It has been tested many times before and has even out done a ported ITR manifold.
Re: my b18c build
Originally Posted by 00Red_SiR
(Post 45130370)
240+hp on stock port pr3 head with a performance VALVE JOB, on a well built 2L motor, maybe. On a 1.8L....not likely.
Re: my b18c build
(Post 45131384)
I agree with you on the 85mm but my motor WILL NOT fall shot of 200whp i set my goal high like i stated before but there is no reason that it wont make 220+ with 81.5mm and my tuner is very good
Re: my b18c build
Why not a 84mm build? id go with skunk2 or or the PX ported, PX has been tested to outperform them
Re: my b18c build
Originally Posted by 94VTEC2TONE
(Post 45132325)
