help me make more power!!!!! dyno inside!!!
Old 06-28-2010, 02:07 PM
  #26
slowcrx954's Avatar
Default Re: help me make more power!!!!! dyno inside!!!
Originally Posted by newtron63h
looking pretty damn good id say, you are looking at somewhere in the 225-235 peak hp range, and 145-153ft/lbs peak at the crank........and since honda trannys use thin fluid i would lean more towards the low side(because theres less frictional loss of moving the fluid..........theres less power being eaten up by your drivetrain). your torque is VERY flat which is very good. i would try playing with the AFR and see what happens there............id have to do some visualizing to see what might be going on with your vtec engagement, but if i have an idea ill let you know.
thanks alot,even for a 1.8 it moves perry dam good.just wanna get it to drive alittle better,falls out of vtec unlees i perfect shift a 9350.
Old 06-28-2010, 07:51 PM
  #27
namewasdallas's Avatar
sounds like a screaming engine reving out to 9000+rpms, get some pictures of the motor and the cam gears, lets take a peak to better help you get it straigned out. this is in a crx correct? whats done to the car beside the motor?
Old 06-28-2010, 08:30 PM
  #28
CHEETAH's Avatar
how much timing advance? why so rich !?!?!?
81mm bore?
i personally think cams are too big for the setup or is bleeding off too much compression, i.e. to lil dynamic compression so mess with the cam gears or get degree specs and degree the motor.
Old 06-29-2010, 04:01 AM
  #29
slowcrx954's Avatar
81mm bore?
81.5 the tunner aimed for that afr,he is a nationaly known.lance hes the cam gear pics,i definlty had the readings backwards i belive.
intake
exhaust
Old 06-29-2010, 11:02 AM
  #30
siregcivic's Avatar
looks to me like its +1 intake and +3 exhaust get a better header
Old 06-29-2010, 01:54 PM
  #31
Uncle Dave's Avatar
81mm bore?
Tuned on E85 I think I read and I would run a GOOD 4 throttle setup on this engine and make use of the cams and sort out a better set of gear ratio's.
Old 06-29-2010, 02:06 PM
  #32
slowcrx954's Avatar
yes it is tuned on e85,yeah a closer gear set will do wonders,header will really open it up,but motor was build for nos,no point in spending 1200 on a header for max 20 hp,or direct port 150hp for 800.seems like a no brainer to me.
Old 06-30-2010, 09:01 AM
  #33
Garrett's Avatar
81mm bore?
I always think the same, but I did a test https://honda-tech.com/forums/all-motor-naturally-aspirated-44/precisionautocanada-com-pro1-vs-pro2-dynotest-2684800/
And pro1 are always better than pro1 on 1.8L+ NA setup
Old 06-30-2010, 01:18 PM
  #34
slowcrx954's Avatar
Originally Posted by Garrett
I always think the same, but I did a test https://honda-tech.com/forums/showthread.php?t=2684800
Thanks for the post guy,so sould I reduce overlap?the cam are degreed in now.also your thread show a stock gsr making more power on pro2,so why wouldnt a ported head and higher compression befeit?
Old 06-30-2010, 01:32 PM
  #35
stumpyf4's Avatar
Actually since he's using tuner camgears (1 mark = 2 cam degrees), it's +2 intake and +6 exhaust. Looks like those gears have been in the negative side before. If they were new for this build do a leak down to make sure you didn't have any bent valves.
Old 06-30-2010, 01:55 PM
  #36
Garrett's Avatar
it was a b18cR engine
your setup need a decent header and exhaust system
do a dyno runs with the exhaust disconnect
Old 06-30-2010, 02:19 PM
  #37
slowcrx954's Avatar
yeah its a ebay header,but im deffintly doing a open header run once i get a new dizzy.the whole engine is new,but the cam gears were on my old setup.motor feels great im going to post some runs later on.first 1.8 with a killer midrange,feels better then my b20/vtec.
Old 09-15-2010, 08:50 AM
  #38
cruizinmax's Avatar
If that wideband is correct that seems like a lot of fuel for e85. There is an extra volume of fuel in the cylinder due to nature of it. Your currently at approx .81 lambda. What happens to the power if you lean it out to say .89? In other words 13.0 displayed on the wideband?
Old 09-15-2010, 09:02 AM
  #39
DDTECH's Avatar
Those cams aren't too big for that motor...
Those gear settings aren't correct, your using older style gears, Go back to your tuner and start at 0 on the intake and +2 on the exhaust.. your too advanced on your exhaust.. do the math, your taking too much away from your power stroke...
the only reason those cams seem sooooo big for that motor is because they aren't degreed in properly and the gear settings are all flubbed... TRUST ME please.. go back, reset your gears to what i said and re tune.
Old 12-12-2010, 03:06 PM
  #40
slowcrx954's Avatar
the richer it was the more power it had.always a plus for a street driven car.
Old 12-12-2010, 03:09 PM
  #41
slowcrx954's Avatar
thanks for your time all motor,it been a while and im going to redyno the car and play around with the cam gears.results will be posted soon!car has been leaked down,and compression tested.290 across the board,less then 3% leak down.
Old 12-12-2010, 03:34 PM
  #42
93egSLEEPER's Avatar
I have a similar situation as you. I too run the WS2 exhaust simply because I like the quietness it provides which is protection from the police in my area. I spoke with my tuner (james @ speedfactory racing) and next time I tune Im going to do a piggy back system. I will tune w/ the exhaust on AND open header. That way I can run my catback and benefit from a specific tune for the added backpressure but when I go to the track I can switch tunes to the open header to get peak numbers for racing. It will cost a few extra bucks but I will have the best of both worlds.
I will gladly drop 8whp on the street to keep the cops off my back and be able to drive up and down the freeway at 4k without hearing loss.
Old 12-12-2010, 05:57 PM
  #43
slowcrx954's Avatar
i hear that!i dont have much problem with cops in florida,im tuned on neptune so i could easly save a new map switch for the track.i will post results of a new header 3in exhaust and cam tuning.
Old 12-12-2010, 06:26 PM
  #44
Right on good luck. The cops in my area are ********. If its shiny it must be loud is their mentality. I got pulled over so the officer could look at my exhaust and hear it unobstructed once. He made me free-rev it and once he figured out it sounded like sex he let me leave. I can't say I dont blame them though, Im tired of fart cans always being obnoxious.
Old 12-12-2010, 11:02 PM
  #45
tempsohc's Avatar
A/F's look rich?
Old 12-12-2010, 11:59 PM
  #46
DDTECH's Avatar
He's gone back and changed it, i'm pretty sure he'll be more happy now..
a starting point should be like i stated above.. hope it all works out, if you need anymore help feel free to pm.
Old 12-13-2010, 07:36 AM
  #47
wreckeddc4's Avatar
What injectors are you using?
On my setup, which is very similar to yours I use injector dynamics 1000s because the cost isnt much more than rc or similar, and I will never run out of fuel with my setup. The spray patterns are also supposed to be second to none, and they idle great.
My motor is a gsr block and head with itr pistons and a 2 layer head gasket. I run a 68mm throttle body and a port matched sk2 intake manifold.
I also run a vteckidd narrow header which alot of people say its not best for making hp, same with my ws2 exhaust. I went to the dyno with my full exhaust setup, but made a strait pipe for the muffler. So the pipes are still only 60mm.
with s300 and e85 I still managed to get to 210hp, with a blox tuner stg 2 cam also.
There def should be alot more in your setup. Do a comp and leakdown test, re degree the cams and try again.
Old 12-13-2010, 02:23 PM
  #48
slowcrx954's Avatar
comp and leak down are good,im useing injector clinic 1050 cc injectors.well see what happins after a retune.
Old 12-14-2010, 05:32 AM
  #49
LHTBill's Avatar
I actually have a somewhat similar setup. I have an 8hp power drop with VTEC at 5800. After a lot of research, I'm very confident that the problem lies with the WS2 exhaust. While I love the quietness of the exhaust, I'm not so happy with the power output.
Old 12-14-2010, 07:58 AM
  #50
Garrett's Avatar
Invidia Q300 is a 70 mm catback and really quiet, it allow great power up to 220-225 whp without to much back pressure, after that I experiment some power lost
allmotorgsr98
48
04-26-2013 04:05 PM
Andrew Sutherland
03-22-2007 04:50 PM
2ltrgsr
26
11-05-2006 06:20 AM
black sohc civic
09-30-2003 05:59 AM
7rrivera7
09-09-2003 03:48 PM
Quick Reply: help me make more power!!!!! dyno inside!!!
