help me decide which cams will get me over 190whp on b16
Old 10-13-2005, 11:32 AM
  #76
strsi's Avatar
Default Re: help me decide which cams will get me over 190whp on b16 (strsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strsi &raquo;</TD></TR><TR><TD CLASS="quote">funny how this came to the top again cuz i posted it so long ago.
anyways, some how this thread got turned into which header i should get instead of cams, but anyways i went with rmf. there is a thread around here showing the results.
as for cams, the general consensus was that i dont have enough displacement or CR to run larger cams so i've decided to stick with my s2s1's. the end. thanks for everyones help </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by todaVTECDA9 &raquo;</TD></TR><TR><TD CLASS="quote">m22x.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sa90eg &raquo;</TD></TR><TR><TD CLASS="quote">just get a really nice header.....dtr, smsp, hytech,anr,rmf ect.....
i think the header will put you over 200....the cams are good. </TD></TR></TABLE>
does no one read? seems like everyone just reads the first post & responds without reading the entire thread
Old 12-15-2005, 05:19 PM
  #77
JerseySiPOS's Avatar
in my b16 STOCK bottom end, made 175whp @ 8300, and 118-122 tq from 6k - 7.5k.
0, 0 on the cam timing with stock headgasket. 23 psi fuel pressure with 370cc injectors (too big)!
Toda B cams, STOCK ITR TB/Mani
When i used a 65mm TB and AEBS manifold i peaked 170whp @ 8900, 115 tq. and this was with 310s and 32 psi fuel pressure.
try CTR cams, or your stage 1s, stock injectors, stock b16 TB/manifold and an ITR manifold and you'll be happy with a good tune and a header with no bigger than 2.25" at the collector throat. this doesn't mean your flange can't be 2.5" where the exhaust bolts to.
mod a B16 exhaust manifold where you would keep the 2.0" outlet, but cut the collector off at the throat and weld a tapered collector out to your exhaust diameter.
you can thank me later.
Modified by JerseySiPOS at 12:11 AM 12/16/2005
Old 12-15-2005, 10:48 PM
  #78
strsi's Avatar
why does this keep coming back up from the dead. already have a conclusion
Old 12-16-2005, 04:12 PM
  #79
American.Graffiti's Avatar
Your thread has become the groundwork for alot of b16a builds. I know b/c Im using the info for my research.
honkyb18c
10-11-2008 07:01 PM
yoorang
17
08-18-2006 10:00 PM
j_fukin_t
07-21-2006 03:36 PM
Fuzion
04-12-2005 10:21 PM
strsi
43
04-04-2005 10:41 PM
Quick Reply: help me decide which cams will get me over 190whp on b16
