grounding kit install...tried searching
Old 01-29-2004, 12:42 PM
GroOvin_aZn's Avatar
Default grounding kit install...tried searching
anyone have pics or instructions to install a grounding kit for a DC chassis?
i tried searching ( ex. ground kit, earth kit, install ground kit, etc) nothing pops up that could help me. if anyone knows of a site, that would really help me out. thanks
Old 02-03-2004, 09:27 PM
Rune's Avatar
the best ground points are from alternator housing to neg on battery...and engine block to neg on battery...try this..your lights will get brighter...i have a circle earth kit i got from okinawa last month.
Old 02-04-2004, 12:30 AM
mey_xanng's Avatar
Default Re: (Rune)
Also replace your stock wires, and be sure to hook up the ground points in series.
Old 02-04-2004, 05:45 AM
00 FBP ItR's Avatar
Default Re: grounding kit install...tried searching (Red@10k)
hit me up.. i'll do it for you in a jiffy.
Old 02-04-2004, 09:43 AM
d16nomore's Avatar
Actually, I provide install instructions with the kits that I sell.
Use these points:
Alternator housing
Valve cover
Tranny
Throttle body
Thermostat housing <-this is the main ground for the ECU.
Tie everything back to a common point as opposed to the end-to-end method. My tests have shown that this will remove fluctuations at the sensor...
Let me know if you would still like some instructions, I'll get them over to you in a pdf
Old 03-01-2004, 08:20 PM
Mindtrap's Avatar
Default Re: grounding kit install...tried searching (d16nomore)
that would be great if you could get some pictorial illustration for b18c5!
Old 03-01-2004, 10:01 PM
DEMNTD1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16nomore &raquo;</TD></TR><TR><TD CLASS="quote">Actually, I provide install instructions with the kits that I sell.
Use these points:
Alternator housing
Valve cover
Tranny
Throttle body
Thermostat housing &lt;-this is the main ground for the ECU.
Let me know if you would still like some instructions, I'll get them over to you in a pdf</TD></TR></TABLE>
Could you send me it on pdf as well.
Thanks a million....
Old 03-02-2004, 05:36 AM
d16nomore's Avatar
Default Re: grounding kit install...tried searching (DEMNTD1)
OK, now I'm gonna sound like an ***, but since I posted this I've had a metric tonne of people asking for the instructions, but not the kit that I developed them for.
So...I've decided not to send out the instructions separately.
However, if there are any other questions I'm more than happy to help out...
Old 03-02-2004, 10:14 AM
Mindtrap's Avatar
maybe you should reedit your original post then
Old 05-14-2004, 04:41 AM
JBBNJ609's Avatar
um thanks then buddy . . . im sorry but im not spending 90 $ usd for your kit
Old 05-14-2004, 06:43 AM
nickgmiller04's Avatar
Default Re: grounding kit install...tried searching (jason bouchard)
just get some 4 gauge wire from lowes/home depot, some good connectors. then find you old grounds, and replace them. you dont need a "kit". i didnt. my lowes wires have been fine for 2 months....
and make sure the wire is flexible. stiff wire is very hard to use.
spent like $10 for wire and connectors. get like 4 ft and youll still have extra. in case you mess up on the lengths
Old 05-14-2004, 10:03 AM
JBBNJ609's Avatar
Default Re: grounding kit install...tried searching (nickgmiller04)
yea good point . .. does anyone have some pics of the stock locations i see some but i wanna do them all
i have a bunch of feed back with my system on and i have a 4 gauge going to my batt for the neg and the pos but it still has feed back only when the amps are on and it gets louder when the rpms are up and its louder when the lights are on or when it rains . . .
Old 05-14-2004, 06:50 PM
95gsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jason bouchard &raquo;</TD></TR><TR><TD CLASS="quote">yea good point . .. does anyone have some pics of the stock locations i see some but i wanna do them all
i have a bunch of feed back with my system on and i have a 4 gauge going to my batt for the neg and the pos but it still has feed back only when the amps are on and it gets louder when the rpms are up and its louder when the lights are on or when it rains . . .</TD></TR></TABLE>
check the ground point for your amp. find a better gound point sand it dawn to bare metal.
Old 05-14-2004, 07:23 PM
JBBNJ609's Avatar
Default Re: grounding kit install...tried searching (95gsr)
its straight from the battery and to the chasis . . .
Old 05-14-2004, 08:57 PM
95gsr's Avatar
i ment you need a very good ground from the chassis to the amp.
Old 05-14-2004, 10:09 PM
dfoxengr's Avatar
Default Re: (mey_xanng)
must not have tried searching hard enough. this topic is covered all the time.
pimpdd101
06-25-2007 04:35 PM
Cowtit
04-28-2003 12:03 PM
Quick Reply: grounding kit install...tried searching
