ENDYN timing belt tensioner
#27
Re: ENDYN timing belt tensioner
if a tensioner can be design to apply pressure to the entire length of the front side, like K20 and F20, then yes. applying point-pressure via a roller to a long length of an oscillating belt is not fixing the problem
splitting the length of the flapping belt with a roller will increase the frequency of the flapping
#28
Homosexual by choice
#30
i'm not quite sure the cam profile has huge effect on the belt slap... it seems more directly resulted from the belt tension itself, and the resonance itself from moving through various engine rpm's... i mean, i think if you film the belt slap with a stock cam, then you put in a huge cams with huge profile i don't think it should change the belt slap much if at all. also at idle and car not moving there's no VTEC/hi cam anyway...
#31
has more to do with the loading and unloading of the belt tension by the crank acceleration and deceleration when the one steps on and off the throttle--road racing comes to mind
#32
I like to party
I had heard it was high ramp angles, not necessarily just big cams. I could be incorrect though.
Either way, I really like mine, it's worth the money for the peace of mind that I won't jump a tooth.
edit: here's the link to Larry's website... like I said, decking and high ramp cams.
http://www.theoldone.com/components/..._tensioner.htm
onesol2remember
04-16-2007 02:10 PM
Cuong-nutz
49
05-01-2005 12:52 PM
