Strange noise when reving motor help!
Old 04-05-2018, 02:37 AM
xlusiveracer's Avatar
Default Strange noise when reving motor help!
I have a B20vtec and at idle i can hear a muffled sound through the intake when I rev it.when I remove the intake and rev it I don’t noticed it.i am gettin jerking,hesitating while driving,has trouble reaching redline,no power.new cap,rotor,plugs,wires,check valve lash,oil is good.i brought it in for an alignment at a shop while it was snowing and only noticed once it snow cleared.
Old 04-06-2018, 03:25 AM
1HGEJ2's Avatar
Default Re: Strange noise when reving motor help!
timing on cams and crank is fine? it sounds like timing belt slip over
Old 04-06-2018, 04:14 AM
Will that cause a noise when reving the motor at idle ?
Old 04-06-2018, 04:24 AM
1HGEJ2's Avatar
mechanicl noise or ?
Old 04-06-2018, 04:37 AM
I would think so.i clean my iacv and vtec solenoid and it kinda ran a bit better.when it’s cruising I don’t notice much jerking,hesitating but when I’m on the gas pedal it does it.
Old 04-06-2018, 07:39 PM
JRCivic1's Avatar
Distributor problem... weak coil or bad ICM.
Old 04-07-2018, 05:43 AM
would that cause that noticeable sound during idle when reving it ?
Old 04-07-2018, 12:48 PM
I have a little video showing the sound but I don’t know how to upload on here
Old 04-08-2018, 07:21 AM
here’s the video listen to when I push the throttle it’s some kind of metallic sound can hear it from intake mostly
Old 04-09-2018, 03:53 AM
Bump.anyone hear the sound
im talking and maybe know what it is?i tried it with the filter off and pipe still connect and still makes the noise.filter/pipe you can’t hear it
Old 04-11-2018, 07:20 AM
Loves Tossing Salad
09chaplak's Avatar
I feel like I had the same noise at one time and it was the distributor going bad, maybe just the cap I cannot recall.
Old 04-11-2018, 01:43 PM
DID YOu replace the whole distributor?i put in a new cap and rotor.its hooked up to msd blaster
Old 04-12-2018, 04:58 AM
Loves Tossing Salad
09chaplak's Avatar
Yes, I said the hell with it and just ordered a new one. But that was me, I didn't feel like properly diagnosing the entire inside of it.
Old 04-13-2018, 05:12 AM
nkowi's Avatar
Before you go throwing money at new parts you might consider looking for vacuum leaks.
_
Old 04-16-2018, 12:25 AM
_
I’ll check.you have a good place to start?did you listen to the video?do you hear the metallic sound when I push the throttle?
Old 04-16-2018, 12:26 AM
did that fix it
Old 04-16-2018, 05:19 AM
Loves Tossing Salad
09chaplak's Avatar
did that fix it
It is or is not fixed?
Old 04-16-2018, 04:08 PM
I’m asking you if changing it fixed it?
Old 04-17-2018, 06:04 AM
Loves Tossing Salad
09chaplak's Avatar
Oh lol my bad. Yes it did, but that was just my specific example.
My advice is to diagnose it properly before buying a new distributor, I was just lazy and gave it a shot. Crap shoot was in my favor that time.
joshblaze101
08-26-2009 09:02 PM
masijdm
05-12-2009 05:42 AM
DesiDez
Honda Civic (2001 - 2005)
12-29-2008 08:08 PM
d124g0n
07-21-2005 06:29 PM
MaxPowerIntegra
07-29-2001 01:00 PM
Quick Reply: Strange noise when reving motor help!
