built engine problem!!!
Old Sep 26, 2011 | 03:47 PM
cibao2ner's Avatar
Default built engine problem!!!
so im finishing my swap..and its in the car finaly...i tried spinning it by hand and it spins fine but when its about to get to tdc it feels like it locks like something is touching and i have to force it to get it at tdc....
engine is a built lsvtec
12.5 compression pistons,scat rods,buddyclub iv cams, supertech valvetrain,
it spun fine in the engine stand the only thing that has change is flywheel and clutch install and tranny...
Old Sep 26, 2011 | 03:51 PM
DDTECH's Avatar
Default Re: built engine problem!!!
..Compression..? You're spinning the motor with hands.
Spring pressure, how big the cams are.. this all plays a role in how hard it is to spin over.
Old Sep 26, 2011 | 04:07 PM
cibao2ner's Avatar
it has no sparkplugs yet...its using the supertech springs the 70lbs and buddy club spec 4s..its spins hard but then it gets to a point where it feels like it locks and i had to use a pipe on the 1/2 inch ratchet to keep it going...
it was spinning freely on the stand...i hope something isnt **** up on the clutch its the only thing im reusing from the old engine which ran fine...and the only variable that change from stand to car...tranny is in neutral also..
Old Sep 26, 2011 | 05:37 PM
PyroProblem's Avatar
This doesn't sound right to me either...
Old Sep 26, 2011 | 06:17 PM
cibao2ner's Avatar
someone told me it might be p2v contact....but it shouldnt be touching on the small lobes..if it was on vtec i would have notice cause i degree them in on the settings it has now...but that how it feels like something keeps it from spinning smoothly
Old Sep 26, 2011 | 06:44 PM
Shouldn't need a breaker bar to turn an engine over that has the plugs uninstalled...
Agreed. Much more clearance between the valves and pistons when your not in vtec.
Perhaps try having a friend hold the clutch in while you rotate the engine???
Old Sep 26, 2011 | 06:58 PM
cibao2ner's Avatar
my tuner is gonna pass by wednsday to check it out he told me it could be p2v but slave cylinder isnt installed yet for the clutch gonna try that tomorow n press in the clutch...
Old Sep 26, 2011 | 08:28 PM
hoffmanb16's Avatar
Your going to install the slave then press the clutch right?
Just making sure...
Old Sep 26, 2011 | 08:37 PM
cibao2ner's Avatar
yea...
Old Sep 27, 2011 | 04:00 AM
N/A's Avatar
N/A
Purpose Built
Why wait for someone else? Just wedge a piece of wood or something on the clutch fork.
I wouldn't keep forcing it with a breaker if it keeps up tho...
Old Sep 27, 2011 | 02:02 PM
cibao2ner's Avatar
i put the slave cylinder and press the clutch a couple times and spun the engine and it spins fine now....dont know wtf was wrong....new engine 1st engine built by me so u know why im worry....and dont have anymore time or money to get another one on the car for now...
Old Sep 28, 2011 | 11:22 AM
Mr. EG's Avatar
Sounds like you figured it out. My next question was going to be "did you use the alignment tool properly and did the input shaft slide in with ease".
Old Sep 28, 2011 | 01:18 PM
crxsi1's Avatar
ya thats happened to me before with the input shaft slightly miss angled, causes it to slightly bined of course i was on my back under the car in 10 degree weather, sucked.... the last time i did a clutch i put an ever so slight bit of anti-seize and i mean as little as u can on the splins and it slides right in u just have to be careful not to put to much cause u dont want to get that crap on the clutch... good luck hope it runs well
CleanLikeJdm
Feb 11, 2005 05:36 PM
JD_B18CDX
Jan 28, 2002 11:04 AM
