Building a P8R head
#26
Re: Building a P8R head
I'm starting the journey to build a p8r head.
I ordered b20a intake valves, I'm going to order b18b1 exhaust valves and integra GS valve stem seals.
I've been sitting on a set of aftermarket steel springs and retainers for an LS that I haven't been able to use since none of my LS builds get finished lol but I'm going to use them too.
Will update as I go...
Also I measured pr4/p75/p8r cams...p75 are the most aggressive, either out of b20z or b18b1
#27
PR4 cams should actually be the same lift as the P75's but with 2° more duration on both lobes. Hard to measure unless you're in the process of degree'ing them and you happen to being doing both sets back-to back.
From Rocket Motorsports spec sheet:
#28
Got mine back from machine shop
new valve stem seals too
waiting on some things before i install either on b20z2 or b20b block.
i know the compression drop bc of the chamber but i hope it will give my b20 a little more umph
#29
Was bored at work and stumbled on this...answers in case anyone searches...
My built p8r head ended up on a 1.8 block.
It's been about 150 miles since this setup went in the car.
Runs strong. Aftermarket valvetrain is a little noisy.
Cammed. Would love to turn the revvs up more..still cleaning up the tune here and there.
I hope to, in the future use this head on phk piston b20 with cams. Fairly sure clearance is ok...max lift on anything 403 ish is 10.7
#31
#33
Aftermarket pistons typically have valve pockets that are sized for the larger VTEC valves... especially forged ones. If you don't try to use the OE B20B/Z pistons, you won't have to fear v2p contact.
#35
I used Nippon pr3 on another motor I assembled, but haven't ran it yet. It has c1 cams so I was never worried about clearance but I did hold them up to some stock pr3 and could tell they dug valve pockets a little further on the aftermarket.
I am considering using PHK piston to keep the price down, but we will see when the time comes. I have a set of p3f pistons sitting around that would be fairly painless to swap to. Since thats the piston that comes on the p8r headed b20, I know it's good as per clearance.
@spAdam - we'll see what happens (esp with funds) when I start teardown and reassembly. I can't decide. 260/260 or 272/260 both sound like good combo to me...esp if either combo will run on OEM ecu. Saves me from having to chip ecu...
Undecided if I boost or not as well. Would like to get it together and running first before deciding
baynedo
Mid-Atlantic (Sales)
05-27-2011 01:55 PM
( o )( o )
10-19-2005 07:52 PM
