Broken Engine Mount--Fixable?
Old Feb 15, 2012 | 01:54 PM
C_Rock77's Avatar
Default Broken Engine Mount--Fixable?
Is this fixable? What would it take to repair it?
Old Feb 15, 2012 | 03:34 PM
DDTECH's Avatar
Default Re: Broken Engine Mount--Fixable?
IF you know someone good @ arc welding, and you have the other piece, its possible to fix.. other then that.. start searching for another block lol..
Old Feb 15, 2012 | 03:46 PM
Deetz's Avatar
Crazy Honda Guy
That is not your engine mount, it's the block. It looks very damaged alright, even the other holes are stripped.
You are probably best off with another block
Old Feb 15, 2012 | 04:16 PM
SP GARAGE's Avatar
I have a b20 block same condition... I always thought bout putting the 3 post mount on and welding it on and letting it ride
Silvertc's Avatar
I had the SAME eact thing happen to me, I had a friend come over and we put bigger studs and retaped it while the motor was in the car. never happened again.
Old Feb 15, 2012 | 07:30 PM
5.0 Killa's Avatar
If you have the piece that came off you may be able to tig it back in. Typically aluminum weld are never as strong as the parent material though. A better question is how did it break?
Old Feb 15, 2012 | 08:10 PM
C_Rock77's Avatar
It's on a longblock a guy has for sale. AFAIK, it broke in a wreck. I didn't figure it was something that was very easily fixed. Thanks for the input, Guys.
Old Feb 16, 2012 | 04:23 AM
hondaaccordagp's Avatar
If you have the piece that came off...i think you may be able to tig it back in!!
Old Feb 16, 2012 | 09:43 AM
guachi1209's Avatar
throw the block out same **** happen to my boy we took it to get welded lasted 3 months, then same thing happen again at the track
Old Feb 16, 2012 | 05:24 PM
Salami's Avatar
All 3 of those holes are ****ed up. Throw the block in the trash after it is stripped of the good parts.
Old Feb 17, 2012 | 12:09 AM
93egSLEEPER's Avatar
too much VTAK yo
Old Feb 17, 2012 | 05:40 AM
Mr. EG's Avatar
I personally would weld the mount right to the block.
Old Feb 17, 2012 | 06:31 AM
5.0 Killa's Avatar
A steel mount to an aluminum block?
Old Feb 17, 2012 | 07:23 AM
Str8EJ's Avatar
If you're talking about the mount bracket, you can't weld steel to aluminum.
If you're talking about the actual mount, the later version aluminum mount, I don't see the point. It would be ghetto & you'd need to remove the engine everytime the timing belt would need to be replaced.
I'd pass.
Old Feb 17, 2012 | 09:03 AM
mygoldeneg's Avatar
so your going to weld cast iron to aluminum good luck with that
Old Feb 17, 2012 | 09:15 AM
FlewByU352's Avatar
This makes me realize how lucky I am that the weak point in my accident was the HASPORT mount. The frame separated enough to where it sheared all my belts and cracked off my power steering pulley but just missed touching the motor.
Old Feb 17, 2012 | 10:24 AM
DC4KiD's Avatar
Does that only happen in accidents?
Old Feb 17, 2012 | 10:28 AM
hybrid_KJ's Avatar
I've repaired way wose than that. All you need to have done is have two of the holes time serted or heli coiled and then weld the other hole up completely and add material to make up for the missing piece. Use the mount bracket and your two good holes to locate and drill and tap the third hole back in. In the past I repaired a block that had two of the holes ripped out along with alot more material than that block and I fixed it in this way. It was a sleeved block and worth fixing though.
Old Dec 2, 2018 | 12:47 PM
Luis Diaz's Avatar
what studs size did u use
cmamtower
Oct 23, 2010 08:53 AM
DCTegg
Aug 23, 2009 12:00 PM
biggoofy
Feb 13, 2009 06:28 PM
teamitr
Nov 17, 2005 07:09 PM
eda6
Jun 20, 2004 03:46 AM
