86mmx95mm setups life??
i was wondering on how long do people 2.2l setups last running such a big stroke and usually really high compression on top of that and i know with that big stroke eating bearings and and teperig the cylinder walls up so was wouldnt on how often people have to rebuild those kind of setups???
thanks..
thanks..
Re: 86mmx95mm setups life??
15,000 miles on my h23 crank 88mm bore h23 runs great racing at import showdown next weekend . Its how you build it man .
IMO, if I was building something for a STREET application, I wouldn't go above 85mm bore. But then again, I tend to err on a conservative side.
Well look at my build on here. I am extremly hard on my car. Only problem i had was a crapy eagle crank use the crower. And other good parts it will be fine.
