Anyone using Acura RDX injectors? 410cc - $37ea
#602
Re: Anyone using Acura RDX injectors? 410cc - $37ea
so im really considering trying these on my 97x86 13.0:1 with 272 regrind. I drilled my fuel rail to fit modded k20 injectors which I have been running for a year and I have a 255 walbro. wonder if these will be enough. im on e85. how much power can these support n/a and at what pressure? my build is in my sig.
#604
from this page it seems like they are underrated or was it just the batch tested.
http://www.8thcivic.com/forums/super...injectors.html
whats up with those cc numbers.
why are they rated at 410 and seems like they flow a bit more than 410cc at stock psi.
#607
So I just installed my injectors and wanted to give some guidance.
1. Go ahead and clip the hook on the RDX injector. (Just do it for piece of mind it takes 2 seconds)
2. Remove the rail, and the o-rings in the manifold.
3. Bore out the manifold rings so they can slip over the injector. (I decided to leave mine off)
4. Re-install in reverse order.
Notes- Be careful with the o-rings in the adapter top hats going into the rail. Had one rip when I was trying to install it and had to use the o-ring off the stock injector.
Hope this helps.
Hope this helps.
#608
since i'm going to buy a new set of rdx injectors
is it better to upgrade to an adjustable fpr too??
right now i'm using a walbro 190 lph and stock fpr
on allmotor stock internals b18c dc2 engine with bolt ons.
#610
#612
Xenocron sells a kit and I know they are blue if that's what you're after. OEM are blue...so IDK where black ones are coming from.
#614
This is not a great idea... way too much work to use that particular injector. The top is larger in diameter than the openings in your fuel rail... so you will have to drill out the rail or spend $$$ on a replacement fuel rail that is already set up for "K" series fuel injectors. This defeats the cost benefit of using the RDX fuel injectors.
#615
#616
https://www.xenocron.com/products/rd...=5071558344741
#617
Xenocron sells b series fuel rail adapters that just go on top of the rdx injectors and fit right into place. It's not as hard as you make it sound.
thanks man I got some adapters off Amazon now just waiting for my ryewire injector adapters to come in
#618
SeVeNisOnE
10-26-2008 03:43 PM
577HondaPrelude
11
11-04-2006 07:47 PM
VTC_CiViC
10-30-2003 09:21 AM
Houston Hatchback
06-02-2003 07:39 AM
