To all my H-t fellows i found the serect to making an extrat 30% gain to ur setup
#26
King of the One Liners
Re: To all my H-t fellows i found the serect to making an extrat 30% gain to ur setup (civicxpress)
I too expected the " supercharge any honda ordeal"
And after reading this pointless nonsense i really wish it was, at least i could have just clicked the back button and forgot about it. But this is just incoherant babble.
Bent valves FTW !!!!!!!!!!!!!!!!!!!!!!!!!!!!
#27
I think hes saying the head and the RIDICULOUSLY oversized fuel system did it? change the head and triple the fuel, thats it man!!
#28
Re: To all my H-t fellows i found the serect to making an extrat 30% gain to ur setup (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">
Difficult to read the charts and the differences between dyno runs is not clearly spelled out.
For instance:
The gains/losses on the chart are clearly explained and easy to understand.
i ll go and get a better print out with darker graph colors
For instance:
#29
Re: To all my H-t fellows i found the serect to making an extrat 30% gain to ur setup (rochesterrice
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LumpyTheGrumpyCamshaft »</TD></TR><TR><TD CLASS="quote">doubt the op will share his drugs.. don't post when stoned bro..
(puff puff pass tho)</TD></TR></TABLE>
ur going to look pretty stupid when
i share the sercert
i share the sercert
#30
Re: To all my H-t fellows i found the serect to making an extrat 30% gain to ur setup (2fastGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fastGSR »</TD></TR><TR><TD CLASS="quote">I too expected the " supercharge any honda ordeal"
it s ok
rookies like u can t read dyno sheets
so i expect stupid comments like this
it s ok
#31
Re: To all my H-t fellows i found the serect to making an extrat 30% gain to ur setup (LSvtecMike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtecMike »</TD></TR><TR><TD CLASS="quote">So is the OP going to share something...or make us all guess. </TD></TR></TABLE>
i will tell u when someone can point out the difference............
#33
Re: To all my H-t fellows i found the serect to making an extrat 30% gain to ur setup (rev-speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rev-speed »</TD></TR><TR><TD CLASS="quote">i will tell u when someone can point out the difference............
I see that you have been taking lessons from the Master of His Own Fictitious Universe. Cryptic references to obscure factoids and little known theories are apparently becoming the fashionable stock in trade for the H-T'er in the know.
Post the sheet and explain the changes between the runs that account for any gains or losses that you may have seen. Simply and concisely. Let us all in on it.
#34
40 whp from a ported head and different cams, not bad, but its no missing link. any time slips to make a real comparison.
#35
Re: To all my H-t fellows i found the serect to making an extrat 30% gain to ur setup (bluedlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedlude »</TD></TR><TR><TD CLASS="quote">40 whp from a ported head and different cams, not bad, but its no missing link. any time slips to make a real comparison.</TD></TR></TABLE>
the head is worth less since the valve s bent
the bigger cam s potention is not being used
look at the power band dies at 7.5k rpm.................
#37
it s ok
so i expect stupid comments like this </TD></TR></TABLE>
haha rookies like me .... thats a good one.
If I am a rookie then i wouldnt even know what you would be considered my friend.
Obviously I am not the only one who thinks you have a learning disability by the way that you post , and the lack of intelligent content there within.
So please keep on with your nonsense about you" secret info" as we all sit back and have a nice laugh-
You are a prime example of why the saying in my signature holds to be so true.
Carry on -
it s ok
Carry on -
#38
Re: (S@nt0s)
Retards! He is trying to see if you can figure out how he gained the extra HP!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s »</TD></TR><TR><TD CLASS="quote">559 at it again </TD></TR></TABLE>'
ya mama!
ya mama!
#39
Re: To all my H-t fellows i found the serect to making an extrat 30% gain to ur setup (Used2beAb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Used2beAb16 »</TD></TR><TR><TD CLASS="quote">Its on a different dynojet</TD></TR></TABLE>
same dyno
same dyno
#40
Post the sheet and explain the changes between the runs that account for any gains or losses that you may have seen. Simply and concisely. Let us all in on it. </TD></TR></TABLE>
tommorrow i will go to methodmotor works to get the dyno sheet with darker colors
#41
i know what he did to make the extra power
but im not saying nothing.................
#42
Why not post it.. Se what i dont understand is how you want us to tell you what you did..
nobody's an idiot from what you did
you went with a b16 head(lowers your compression)(also ported, improved flow)
you went to a s2s3 cams vs a junII
bigger tb, different valvetrain and different fuel setup.. i'm sure since the cams are bigger you'd pick up some whp..same with bigger tb, and a b16 flow probably out did the gsr one stock for stock but a small margin..
even then you didn't make 220whp, share the serect, make me look stupid, please.
#43
moderator emeritus
Re: To all my H-t fellows i found the serect to making an extrat 30% gain to ur setup (sa90eg)
post info or prepare to lose points and thread be deleted.
#44
Location: Looking for Vagina in your Mamma,, skeet skeet
Re: To all my H-t fellows i found the serect to making an extrat 30% gain to ur setup (98vtec)
danm son.....prepare to be docked
#49
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">post info or prepare to lose points and thread be deleted.</TD></TR></TABLE>
kind of severe dont you think?
#50
hmm....someone appears to mean business
