All motor setup
All motor setup
So im gathering all my parts for my b20b/gsr/vtec
Im going all motor shooting for 230hp 170+trq
This is my first build
GSR head
-supertech springs,valves and retainers
-skunk2 cam gears
-skunk2 stage 2 pro2s cams
-ARP Head studs and bolts
B20b Block
-rs machine pistons w/rings 84.mm
-Eagle rods
-block guard
-AEM Cold air intake
-DC headers
-skunk2 pro manifold
-blox throttle body 72mm
-255 fuel pump
-440 cc blox fuel injectors
-p28 ecu
-skunk2 catback
gsr tranny
GSR head
-skunk2 cam gears
B20b Block
-Eagle rods
-block guard
-DC headers
-255 fuel pump
-p28 ecu
-skunk2 catback
gsr tranny
Re: All motor setup
Sounds like a decent parts list. However, go with a better header. Take a look at PLM header's. I have a bunch of the stuff you're looking for, for sale. Take a look at my thread's
Re: All motor setup
Check out my build thread. I put down 220 on a dyno dynamics that is known to read around 10% low compared to everything else in my area. Still have cam tuning to do...
Re: All motor setup
parts list sounds solid for the most part. i def second the comment about a better header. also which skunk2 exhaust are you using though? power wise a 3inch is your best bet, and the only skunk2 exhaust that is is the megapower RR. and which aem cold air? 3 inch is also your best bet for that, and only the itr model is that size. if you don't already have the intake id suggest going with a 3 inch short ram with a velocity stack. as for the numbers your hoping for, 230 is def attainable, 170 is shooting a little high though.
Re: All motor setup
I like to party
Re: All motor setup
Fuel pump is massive for the power levels you're shooting for
header is garbage
throttle body is too big since the skunk manifold has s 64mm port opening
those injectors are old technology, Injector Dynamics or a similar Bosch style injector will make more power
I'd personally run a smaller cam like a Blox C, tuner 2, or Pro 1
Why not go 85mm on the pistons? B20 blocks are cheap.
A B16 transmission will be faster
header is garbage
Re: All motor setup
header is garbage
header is garbage
Actually the pump he's using is the smallest he should go for as far as his goal.
Re: All motor setup
Re: All motor setup
I wouldn't waste money on the "block guard".
I would go 85mm amd css it, if the budget allows. Also a 4.7 or 4.9 final drive would be a blast.
I'd change the header, intake manifold, and switch to rdx injectors. The fuel atomization is great. The droplets are an impressive 50 microns.
Nothing wrong with the 255, they are cheap and leaves plenty of growing room if the setup changes in the future.
Re: All motor setup
I've also tested on my own car that 255 is the smallest I'd go on even a naturally aspirated motor. Trust me 255 or more if needed is the way to go.
Re: All motor setup
GSR head
-skunk2 cam gears
B20b Block
-Eagle rods
-block guard
-DC headers
-255 fuel pump
-p28 ecu
-skunk2 catback
gsr tranny
GSR head
-skunk2 cam gears
B20b Block
-Eagle rods
-block guard
-DC headers
-255 fuel pump
-p28 ecu
-skunk2 catback
gsr tranny
couple things, some touched upon:
-block guards are absolute ****, they do nothing. blows my mind in 2015 people still buy that ****.
-dc header is garbage, you'll be better off with any other replica custom header ie plm, 1320, and etc(reps of toda, rmf & etc etc)
-225lph fuel pump is fine, I have a 255lph on my internally stock jdm b18c, from when my old b18c1 motor was boosted.
-why blox injectors? get either rc or grams, much better, proven time and time again and same price point. boggles my mind as to why you chose blox for injectors.
-I hope you plan on tuning this setup with hondata or such.
-you're fine with the gsr trans, you should be making enough power that the slighter shorter geared b16 trans wont make much of a difference except annoy you, consume more fuel and put unnecessary stress on your motor.
-get a 70mm tb, i recommend the skunk2 alpha, you can get it for cheap ~$120 shipped....then use the gasket as a template and port match the sk2 manifold to match your tb(70mm).
the rest of your list looks good
Re: All motor setup
They performed will w/ my build and MANY guys have gained 5-7whp just from switching them and adding a little pressure. They like 50-60psi base
Deucedeuceteg
28
05-23-2007 06:00 PM
