Acura TSX Acura TSX Sports Sedan. USDM TSX and Euro/UK/JDM Accord.
speaker dont work. help pls
Old 04-26-2012, 01:11 PM
jdmem12000's Avatar
Default speaker dont work. help pls
ok so i was on my way to the house and the front speaker just stopped working. the rear doors and deck work just fine. i checked fuses and nothing i pull the door panel and took the speaker checked work just fine. they are not getting signal. what can i check next?
thank you....
jdmem12000 is offline
Old 04-26-2012, 01:14 PM
jdmem12000's Avatar
Default Re: speakers don't work. help pls
thank you....
Old 04-29-2012, 12:18 PM
jdmrida's Avatar
Default Re: speaker dont work. help pls
my rear and rear door speakers dont work either and idk if its wiring or fuses
jdmrida is offline
Old 04-30-2012, 12:18 PM
Masho's Avatar
Both the front speakers?
Do you have an aftermarket head unit? A wire could've been loose or theres a bad ground somewhere.
Have you played around with your speakers or head unit at all recently?
Masho is offline
Old 05-01-2012, 11:35 AM
jdmem12000's Avatar
yes both of then dont work and i have the stock radio
Old 05-24-2012, 09:40 PM
EJ2GOON's Avatar
damn, i need help with this too.................my speakers would keep messing up sometimes when i would turn...........now only my left door speaker works, but sounds shitty........please help.
EJ2GOON is offline
Old 05-25-2012, 05:26 PM
94rs-turbo's Avatar
I work at Acura and these commonly go out, if your in the 4yr 50k range it will be replaced under warranty GLW it guys
94rs-turbo is offline
Old 06-28-2012, 10:38 PM
Trunka's Avatar
buy a book call --- TSX Electrical troubleshooting Guide 2004 this will help you
Trunka is offline
Old 08-01-2012, 02:13 PM
Jvillefinest's Avatar
sounds like the speaker is blown. It is possible for a speaker to go out and come back. Usually when this happens though sq sucks. Its basically the speakers voice coil saying its on its last leg.
Jvillefinest is offline
Old 02-12-2022, 04:10 PM
Mathew Finlay's Avatar
what was the dealer fix?
Mathew Finlay is offline
msinsky14
08-07-2006 06:55 PM
Quick Reply: speaker dont work. help pls
