a/c clutch does not engage 97 acura tl 2.5
a/c clutch does not engage 97 acura tl 2.5. When a/c switch is pressed compressor comes on for 2 to 3 seconds and then shuts off. Checked refrigerant pressure and checked good. when High pressure switch is grounded compressor comes on, please help!!!!!
Modified by jetblast at 7:44 PM 6/8/2008
Re: a/c clutch does not engage 97 acura tl 2.5 (jetblast)
check for voltage an ground at comp if you have both votage and ground replace field coil on compressor.
lleung1980
07-08-2015 09:22 PM
sonnyny
Honda CR-V & Element
06-10-2012 10:07 AM
