Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
98 3.2 TL, intrested in purchasing, any probs?
Old 08-16-2004, 07:26 AM
WhiteTegSE's Avatar
Default 98 3.2 TL, intrested in purchasing, any probs?
Anyone know of any problems or had any problems with these cars... My boss is thinking of buying one we have on the lot here we took in on trade... its got 97000 miles on it...
any posts would be appreciated! Thanks
Old 08-16-2004, 09:50 AM
Pure Adrenaline's Avatar
There were two recalls on that particular year model --
99-023 MAR 01 Recall - Lower Ball Joint Replacement
99-038 AUG 99 Recall - A/T Extension Shaft Sealing Bolt
Make sure that the vehicle has received both recalls.
Other things to look out for are --
Brakes, creaking noise while turning, rear wheel noise, etc.
Other than that, just watch for the usual stuff like evidence of accident(s), alignment, unusual wear/tear, check all fluids to make sure it's been properly taken care of, etc.
Old 08-18-2004, 05:44 PM
nota944mechanic's Avatar
be very weary of the automatic trans. they have had a lot of trouble with these.
Old 08-20-2004, 04:48 AM
The Wolf's Avatar
Default Re: 98 3.2 TL, intrested in purchasing, any probs? (WhiteTegSE)
make sure both recalls have been performed. check rear transmission stopper mount for breakage or cracking. take a look at the a/c idler pulley and a/c clutch as well. be sure to check the differential fluid, level & color. test the operation of the master window switch also, very expensive to repair.
Old 08-21-2004, 03:16 PM
HQuakers's Avatar
The tranny problems were only for the 99-01 TL's. The car was built in Japan, unlike the newer models. It's built like a rock.
Old 08-21-2004, 08:11 PM
Default Re: (HQuakers)
Bwahahaha!!!
Sorry, but I find your statement hilarious.
Mine's an '03 TL-S, and the transmission is the only part that was built in Japan. The rest of the car assembled in Ohio. The only part of the car that was built in Japan is the one causing the most problems.
"Built in Japan" no longer automatically means highly reliable, or rock solid.
jumal
09-21-2011 05:24 PM
beantowncoupe98
Suspension & Brakes
01-29-2011 05:49 AM
sql_civic
06-02-2009 03:04 PM
Elvis1977
12-31-2005 06:03 AM
00civicsimobstyle
11-20-2002 01:34 PM
Quick Reply: 98 3.2 TL, intrested in purchasing, any probs?
