91-95 Acura Legend Pre-Fabbed Supercharger Kit?
Former Moderator
I have a customer with a 1993 Legend. He is inquiring about superchargers, and I've honetsly only seen one Legend that had a supercharger on it, and I *think* it was a Vortech unit.
Does anyone know of any links/info on any possible full supercharger kits for the 91-95 Legend?
there has been a lot of talk about the legend engine spinning backwards compared to most other motors, but i am not sure if that is correct or not.
personally, i think you would have more luck if you had a roots setup instead of a centrifugal. because then you would have to make a custom manifold, but you wouldnt have to worry about all the crap that goes along with custom mounting a centrifugal.
one of the closest things to what could fit a legend motor (2nd gen that is), would be an NSX supercharger. but since the width between the heads on the DOHC nsx motor is narrower than the sohc setup on the legend motor, the manifold you produce would be a good amount wider.
but no, there is not any sort of pre-fabbed forced induction of any kind for the 2nd gen legend, unless you are talking about nitrous
1993, 91, 94, 95, acura, centrifugal, charger, coupe, kit, kits, legend, super, supercharger, superchargers, turbo
