3G TL "Shaved" Doorlock Mod
<U>DOOR LOCK "SHAVE" MOD:</U>
Tools needed: One small flathead screwdriver
Time: 5 minutes (if you are a slow worker!)
Result: Smoothed Out/Shaved Look! Matches all other handles on car!
Process Description:
Replace the small cover on your drivers side door handle that has the key hole in it with an identical cover (same part#) that matches the back driver side door that has no hole...very easy to do and cost is VERY cheap! Pics below....
End Result:
End Result:
Re: (Type R 2c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type R 2c »</TD></TR><TR><TD CLASS="quote">Do you have to get the cover painted or can you order it already painted with your color code? </TD></TR></TABLE>
they come already painted like that
