question about 02 civic si hubs
all im needing to know is for me to go five lug on a 02 civic si can you just swap the 5 lug hubs and the rotors from a 05 civic si can you still use the stock 02 si's
brake calipers
thanks
brake calipers
thanks
my friend did this swap on his ep3 you'll need the 5 lug hubs and rotors thats itand yes you can use the stock oem calipers. for the front thou i THINK you might need to get the 05 civic si or some rsx axles.
Re: question about 02 civic si hubs (ghettochild)
This isn't a TYPE-S swap though. So with that, you should be able to run the same axles. However, there are two different part numbers for the right axle assembly. The left is the same. Something to think about when you do the swap. It may work, it may not work.... I've only done base to TYPE-S/R swaps.
-Victor
-Victor
bump can i just use 05 ep3 5 lug hubs and rotors and keep my calipers
thats all i need to know
R.Kelley
13
08-18-2006 07:54 AM
spontaneous ep3
11-04-2004 07:51 AM
