Hood Dampers
Now correct me if I am wrong but I was under the assumption that hood dampers are basically suppose to eliminate you having to use the stock hood prop, that being said, WHY THE F UCK DOES THIS CLOWN HAVE THE HOOD PROP UP WITH HIS HOOD DAMPERS?!!!!!!!!!!!!!!!!!!!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by angel_i »</TD></TR><TR><TD CLASS="quote">maybe they are blown? </TD></TR></TABLE>
LMFAO... blown from to much heavy weight from the Hood even tho they are rated for heavy heavy hoods.
I wasn't going to go calling him out on that, I was kinda gonna give him a pass on that one but since you brough it up, NO F UCKING KIDDING!!!!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phthalo »</TD></TR><TR><TD CLASS="quote">don't hood dampers raise the hood kinda low? maybe the stock hood prop raised the hood higher for whatever he needed it for</TD></TR></TABLE>not really that low
just a little if not the same as stock
mine:
mine:
There is a possiblity
I have a set of Tein hood dampers and i read somewhere in the instructions or something that they are to only be used to help raise the hood in case it is too heavy for someone. It says that you should not rely on them to hold the hood up and the stock hood prop should still be used. Just my .02.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the CHR!S »</TD></TR><TR><TD CLASS="quote">why does it bother you so much that you had to make a thread about it?</TD></TR></TABLE>
why would it bother you so much that you had to ask a question about him making a thread about it?
