EP's can hold more than 13.2 gallons of fuel............
Old 11-24-2003, 08:58 AM
B18CXr's Avatar
Default EP's can hold more than 13.2 gallons of fuel............
yes, I was running on fumes when I filled up.
FYI: if you park your bus with the drivers rear corner higher than the others, she'll fit about 2ish more gallons.
Old 11-24-2003, 09:01 AM
TEXN3's Avatar
Default Re: EP's can hold more than 13.2 gallons of fuel............ (B18CXr)
the lines also hold a little bit. but, 1.7 gallons more is hard to believe.
Old 11-24-2003, 09:08 AM
1337 Si's Avatar
Default Re: EP's can hold more than 13.2 gallons of fuel............ (texnteg)
Does anyone else have an issue of the low fuel light going on when you still have 3 gallons left? My low fuel light comes on and the car is on E but only fills up 10 gallons. Anyone else have that issue?
Old 11-24-2003, 09:16 AM
GreenR's Avatar
Default Re: EP's can hold more than 13.2 gallons of fuel............ (Boosted Ego)
Nope i never fill up. Gas is too heavy
Old 11-24-2003, 09:20 AM
B18CXr's Avatar
Default Re: EP's can hold more than 13.2 gallons of fuel............ (GreenR)
trust me, after 60k miles on this turd I have filled it up a time or two......
at most pumps the first "click" off leaves around 2-2.5 gallons more space (provided you have the drivers rear higher than the rest of the kar)
Old 11-24-2003, 09:40 AM
cmdr430's Avatar
it must be nice fillinq up w/ only 13+ gallons, my new rx7 takes a little over 20 gallons, and if im lucky i get 15-17 mpg. so it looks like you are running 87 in that thing. @ $1.32 a gallon. if my calculations are correct. does that affect the performance much, if any.
Old 11-24-2003, 09:51 AM
B18CXr's Avatar
Default Re: EP's can hold more than 13.2 gallons of fuel............ (cmdr430)
unless your running an A2 or boosting, anything higher than 87 is a total waste of $$$
Old 11-24-2003, 09:59 AM
cmdr430's Avatar
TRUE!
Old 11-24-2003, 10:28 AM
97 TYPE-R 312's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote"> FYI: if you park your bus with the drivers rear corner higher than the others, she'll fit about 2ish more gallons.</TD></TR></TABLE>
Yack, glad to see you finally got around to installing the switches!!
-Victor ( who notices the fuel light coming on early too )
Old 11-24-2003, 12:48 PM
Banned
^jefs0ng's Avatar
Default Re: EP's can hold more than 13.2 gallons of fuel............ (97 TYPE-R 312)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97 TYPE-R 312 &raquo;</TD></TR><TR><TD CLASS="quote">
-Victor ( who notices the fuel light coming on early too )</TD></TR></TABLE>
that's what I wonder.. how do you park with driver's side rear up? you just go under there and raise that coil? and I think all lights come on early my oddyssey's light turns on before it even hits red.. of course ef-ers like me don't even get a light so we gotta go by instinct.
Old 11-24-2003, 12:49 PM
Si
Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Ego &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone else have an issue of the low fuel light going on when you still have 3 gallons left? My low fuel light comes on and the car is on E but only fills up 10 gallons. Anyone else have that issue?</TD></TR></TABLE>
Yeah the low fuel light comes on when it gets to empty but then the needle goes back up close to a quarter tank, weird.
Old 11-24-2003, 01:39 PM
DISMANTLERGSR's Avatar
Default Re: EP's can hold more than 13.2 gallons of fuel............ (Si)
93 octane i wish we had that in san diego all we got is 91
Old 11-25-2003, 06:18 AM
chunky's Avatar
Personally, I'd avoid filling up at that pump again. Some gas stations purposefully mis calibrate their pumps so that they indicate that you have pumped more gas than you have actually put in the tank.
I've filled up the ep a time or two as well, and the most i've ever fit into the tank is right around 14 gallons (just a notch under), this is with the car on a relatively flat surface.
next time you go to that pump, get a gallon gas container and see if the pump actually pumps a true gallon.
Old 11-25-2003, 09:00 AM
B18CXr's Avatar
Default Re: (chunky)
I've done +14gals many times before, @ other pumps, in various states......
Old 11-25-2003, 09:06 AM
Brandon Clifton's Avatar
Default Re: (B18CXr)
I just wish gas was that cheap here $1.57/gal for cheap gas blows...
Old 11-25-2003, 10:06 AM
* B A N N E D *
showtymers619's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote"> does that affect the performance much, if any.
unless your running an A2 or boosting, anything higher than 87 is a total waste of $$$</TD></TR></TABLE>
you really think its a waste of money running on the highest octane?.. i would like to kno.. since i drive an EP stock LOL...... i always put 91 in my crv.. which has lower C/R.. and i somewhat offroad it.. i was just told it i was climbing hills and what not. id have less ping in the motor.. specially in hard accelerating.. and draging alot of weight.. i just relatively been safe with 91.. from my experience.. and kinna feel sluggish when i use anything else under
Old 11-25-2003, 10:12 AM
fireant's Avatar
Default Re: EP's can hold more than 13.2 gallons of fuel............ (ShowTymers619)
Hondata does recommend using at least 91 with thier flash in the Si.
Jack, do you even go onto the track with 87?
People swear there's a slight performance difference, but no dynos...yet.
Old 11-25-2003, 11:18 AM
TEXN3's Avatar
its not really a problem. but its something that i've noticed on the many hondas that have been through our family. a few civics, an integra, a legend and a TL. its called being a little optimistic. nothing wrong at all with it.
Old 11-25-2003, 12:27 PM
B18CXr's Avatar
Default Re: EP's can hold more than 13.2 gallons of fuel............ (hatch2k)
the base ING maps in the A3 ECU is very low, there are ZERO gains on the dyno with higher than 87 fuel......
Old 11-25-2003, 12:45 PM
anjapower's Avatar
how do you get your driver's rear higher than the rest of the car?
Old 11-25-2003, 01:27 PM
fireant's Avatar
the base ING maps in the A3 ECU is very low, there are ZERO gains on the dyno with higher than 87 fuel......</TD></TR></TABLE>
Cool, until I get hondata, that should save me $10-$20 a year.
Old 11-25-2003, 09:53 PM
johnkimble's Avatar
i just got an ep coming from an eg.. hot damn this thing gets good gas mileage! its got a huge tank!
Old 11-27-2003, 05:42 AM
taikahn's Avatar
uh , not -- what about Hondata. Ive run 100+ octane at the track and it DOES make a difference. Period.
Old 11-27-2003, 05:47 AM
H-T Order of Merit
George Knighton's Avatar
There seems to be apocryphal information on a couple of other boards saying that after a couple of tanks of 91+ octane, the computer advances the spark curve enough for you to feel it.
I guess those other boards are full of it.
Old 11-27-2003, 06:35 AM
fireant's Avatar
Default Re: EP's can hold more than 13.2 gallons of fuel............ (George Knighton)
Hmmm, whos that guy who has a dyno at work? He should be able to test the theory and put it to bed once and for all.
Modified by hatch2k at 9:52 AM 11/27/2003
Quick Reply: EP's can hold more than 13.2 gallons of fuel............
