DC5 ITR Struts
DC5 ITR Struts
Does anyone know for sure, if the DC5 ITR strut is shorter than the type S?
I need to replace my 2 front ITR struts. I want to keep the ITR spring and top hat. Would like to see my options for replacing the struts only.
Any insight would be great, thanks.
I said I don't want a title!
Re: DC5 ITR Struts (winman517)
Not sure about shorter, but the tie rod arm is at a slightly different angle to compensate for the lower car.
With that said, I do have a set of very low mile A-spec struts that are almost identical to the DC5 ITR struts and they would make suitable replacements. PM me if you'd be interested.
Re: DC5 ITR Struts (Todd00)
pm sent.. I've been doing some research and i found people saying that the ITR struts are a bit stiffer and shorter, not sure if this is valid?
A-Spec struts are slightly shorter (with revised strut-arm angles) and definitely stiffer than OEM struts. Not sufe if the DC5R is even shorter than those.
Still, springs is what determines ride-height and I'm pretty sure the perches will be equal.
I had a set of Tein S-techs (~1.5" lowering) on a set of A-spec struts once and the A-spec shocks handled the teins great. Really great, actually.
turboeh6
07-29-2006 02:35 PM
mstewar
11-29-2004 12:08 PM
When buying ITR LCAs, Shocks, and Springs, how can you tell (externally) that they are ITR pieces an
ESCALVANTE
01-26-2002 09:39 AM
