Acura NSX Honda / Acura NSX 1990 - 2005 || Honda / Acura NSX 2017 -
Need help checking diff oil
Old May 9, 2010 | 08:27 AM
OldCarGuy's Avatar
Default Need help checking diff oil
can anyone tell me exactly where and how to check the oil level in teh rear axle? is it common with the transmission? if so, what lube are you using so the posi-traction clutches are lubed correctly?
i can NOT drive the car after it sat for a couple months.. loud popopopop if it rolls forward with any slight turn right or left.. even with engine off and a very slow roll of the car as soon as to begin to turn ---- popopopop
Old May 12, 2010 | 10:38 AM
Ponyboy's Avatar
Painting Masterpieces
Default Re: Need help checking diff oil
There's really no way to measure outside of just draining the transmission fluid. The NSX takes 3 qts.
Most use the regular Honda MTF, GM Synchomesh, Redline, or Motul. I use the Motul Gear FF Competition 75w140.
93Civic_DC
Dec 9, 2008 02:25 AM
THEFXR
May 18, 2006 01:32 AM
wormix001
Apr 5, 2005 08:39 AM
deadbymorning
Sep 6, 2004 11:01 AM
HiChanDC2R
May 6, 2004 06:09 PM
