Acura NSX Honda / Acura NSX 1990 - 2005 || Honda / Acura NSX 2017 -
K-Series engine swap into an NSX?
Old 07-10-2007, 06:21 AM
  #151
Foreign Symbols
juevi's Avatar
Default Re: (nsxxtreme)
To the OP, way to think outside the engine bay.
Old 07-10-2007, 12:33 PM
  #152
Top Ramen's Avatar
Default Re: (BrakeExpert)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrakeExpert &raquo;</TD></TR><TR><TD CLASS="quote">425lbs? I know its not a straight 4, but that sounds a bit heavy. Wheres all the weight.</TD></TR></TABLE>
Actually, I think its a bit light. Found a reference to an old Honda press release that claims the motor weighs 440lbs. Looks like my "arm dyno," as one poster derisively referred to it, was pretty damn accurate.
Old 07-13-2007, 09:10 PM
  #153
70hphf's Avatar
Default Re: (Top Ramen)
Alright, I've done some research and apparently I was wrong in stating that the nsx engine was high-strung. My bad, I think I got it confused with you.
Old 07-14-2007, 01:46 PM
  #154
Westrock2000's Avatar
Default Re: (70hphf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 70hphf &raquo;</TD></TR><TR><TD CLASS="quote">Alright, I've done some research and apparently I was wrong in stating that the nsx engine was high-strung. My bad, I think I got it confused with you.</TD></TR></TABLE>
Alright, you have to admit that was pretty humorous
Old 07-16-2007, 07:04 PM
  #155
70hphf's Avatar
Aww, nobody want to play wit me!!! I think this thread is done. At the end of it all, if I had the money, I'd just supercharge the C32(?) and enjoy it... I've driven a comptech supercharged '04 and it was a joyous nut-in-your-pants tent-pitching experience I'll never forget. 140 mph at about 5K in 4th gear... f.ck the world.
Old 07-16-2007, 07:09 PM
  #156
70hphf's Avatar
As a matter of fact, I've got a funny story for you all to enjoy and discuss. Sorry this is completely off topic, but I wanted to share the idiocy of one of my former friends and co-workers. This guy took the same 04 sc'ed NSX for a test drive on a rainy day, turned off the TCS, and purposely tried to swing the *** end around like it was a front-engine rwd car... needless to say it ended quite badly and he no longer works with us. What a freakin moron. This car was worth about 110K and had around 400 hp. That's a lot to us blue-collar ****'s here in DE. Apparently not enough to said idiot...
Old 07-16-2007, 10:11 PM
  #157
jvtec95's Avatar
When people talk in car terms, 'high strung' ALWAYS refers to having a high redline, which the NSX does for a v-6.
It has nothing to do with 'nervousness' or 'twitchy' and is not a negative connotation except to redneck muscle car guys who don't like a car that they have to rev past 4k rpm.
Old 07-17-2007, 04:54 PM
  #158
Top Ramen's Avatar
Default Re: (jvtec95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jvtec95 &raquo;</TD></TR><TR><TD CLASS="quote">When people talk in car terms, 'high strung' ALWAYS refers to having a high redline, </TD></TR></TABLE>
I have been building cars for three decades and I have NEVER heard that phrase used in that context. I have heard it used many times in the context I mentioned. Face it, "high-strung" means tempermental or near the limit.
Besides, the guy who made the statement had plenty of opportunities to respond and had nothing. If that is really what he meant, I think he could have done a bit better than "You ever thought about being an english teacher? "
Old 07-18-2007, 10:23 PM
  #159
EFinawesomeman's Avatar
swap a Mugen MF408S , turbo it with the ITB's and call it a day.
Old 07-19-2007, 05:43 AM
  #160
70hphf's Avatar
That sounds about right, EF.
Drop the high-strung ****, it's a dead horse. Top Ramen, you're right, the c32's not high-strung, but you sure as **** are.
car and driver stated that the nsx has a slightly rear-biased weight distribution, (42/58). Dropping in a k-series just might make it 50/50. So, I'm thinking that with some adjustable coil-overs, the nsx just might handle better with the smaller, lighter 4 cyl.
Old 03-30-2010, 05:38 PM
  #161
MaxGeek's Avatar
Default Re: K-Series engine swap into an NSX?
Thread Revival.
It lives.
K20 NSX race car.
http://www.nsxprime.com/forums/showt...26#post1291226
Old 03-30-2010, 07:52 PM
  #162
Top Ramen's Avatar
The timing is perfect - I was talking to a friend about a week ago regarding how cheap an early, high milage nsx is now. We figured somebody, somewhere would grab one and do a K swap this year. If the total weight really does drop significantly (from the swap itself, not just based on the fact they gutted the car) then its kind of interesting. Otherwise, I would still rather have one of Cody's 900 hp C32 cars.
Old 03-31-2010, 07:31 AM
  #163
Painting Masterpieces
Ponyboy's Avatar
With that much effort, I wonder why Ross didn't mount the engine longitudinally?
Old 03-31-2010, 09:49 AM
  #164
Genetically Gay
KILLAB17VTEC's Avatar
drop in the k20/24 in nsx would get good mpg.why not just drop in a type r c32?and call it a day.
Old 03-31-2010, 11:58 AM
  #165
Ponyboy's Avatar
c32s are fairly rare so it's got the whole cost factor against it. In addition, b/c the cylinders are lined w/ an FRM, it can be argued that the c32 isn't as robust as a stout k series. Plus, the c32 weighs more.
You ever try an price or even locate a type-r c32?
Old 03-31-2010, 12:36 PM
  #166
Top Ramen's Avatar
Shawn,
If you buy an NSX to build it comes with a C motor, so the rarity is not really an issue. Besides, C30/32 motors aren't THAT rare and the cost factor is largely offset by the custom fabrication required for the K motor. I can't even imagine how many hours re-building the harness to run off a K pro would take. A scratch built M4 harness would probably be easier.
Don't get me wrong - I am a big fan of K motors and think they are the best current 4 cylinder - but this is a LOT of work to get the same power a sleeved C30 or C32 would make.
Very interesting project and I respect the fabrication skills, its just not the path I would choose. If they go out and beat the Factor X car in time attack events, then I would be convinced.
Old 03-31-2010, 05:54 PM
  #167
judgeDredd's Avatar
Here are some pic of a project STMPO was working on 2 years ago i dont no what happen with it.
Old 03-31-2010, 06:57 PM
  #168
Ponyboy's Avatar
I'm speaking specifically of the c32. As far as I've cruised the various online marketplaces, the c32 are much more rare than the c30. Just the build numbers of '02+ NSX's would attest to much less c32s vs. c30s. That was the point of my reply. You can't just "drop in" a type-r 3.2 as it doesn't make much sense and that particular engines' rarity would be make it virtually a pipe dream.
c30s seem to be going for around 9k+ used now. I can't hazard a guess of what a type-r 3.2 would go for. 20-30k?
Old 04-06-2010, 07:04 AM
  #169
something different
redzcstandardhatch's Avatar
what a cool idea.
-goes to look for blown engine NSXs
Old 04-06-2010, 08:50 AM
  #170
845_dapek's Avatar
http://www.nsxprime.com/forums/showthread.php?t=134599
Old 04-06-2010, 10:26 AM
  #171
thundernoodle's Avatar
I wonder if a 289 or 302 would fit in there.
Old 04-06-2010, 04:24 PM
  #172
2ed6sbandzc's Avatar
thread/
Old 05-02-2010, 10:14 PM
  #173
Scotty Dosent Know's Avatar
I didnt read the whole thread but did any one bring up the thought of droping in a newer TL type SH motor in there? 305hp, 273 lb-ft. 3.7 If you blew up the original C30 I would think that this would be a good replacement if you wanted to keep it a V6. Im sure that motor with FI would be alot of fun
Old 05-03-2010, 10:51 PM
  #174
ediddynsx's Avatar
The C30, C32 engine itself just sounds great once you have a proper exhaust on there like the gtlw. As far that C32 R motor....theres not much difference besides a blue printed and more balanced motor.....a 3.8L stroker motor will do the trick just fine.
Kudos to Ross for taking on a project like this.
Old 05-22-2010, 12:53 PM
  #175
jdm Ef-9's Avatar
exactly, the idea is dope, dont get me wrong. i love seeing and doing different but with gains and advantages, the c32 engine is just better exp with a supercharger, ive been in one to and that boost through a c32 is just insane..... got my blood spiking as bad as my 10 second drag banshee...
Quick Reply: K-Series engine swap into an NSX?
