engine rotation
I did search, but turned up no results.
Does the NSX engine rotate in the same direction as the new iVtec engines?
I'm asking because I noticed the orientation of the engine. It appears (and I am speaking only from picture experience, mind you, not owning one myself) that the engine is mounted with the transmission on the driver's side (under the intake manifold) and that would indicate that the engine spins the opposite of my Prelude.
Is that correct? or have I got it wrong?
thanks in advance.
thanks in advance.
