wrong distributer cap?
Old Apr 1, 2007 | 08:05 PM
kpop's Avatar
Default wrong distributer cap?
went to acura today for a new cap and rotor. the motor is jdm and the cap was different rotor worked tho. anyone know what cap is for the jdm itr? thanks
part# was p72 something. will post the part number i got later tonight
Old Apr 1, 2007 | 11:37 PM
neo_'s Avatar
Default Re: wrong distributer cap? (kpop)
P72 is a GSR Part number.
The GSR and ITR distributors are Identical.
Old Apr 2, 2007 | 01:57 AM
kpop's Avatar
Default Re: wrong distributer cap? (neo_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ &raquo;</TD></TR><TR><TD CLASS="quote">P72 is a GSR Part number.
The GSR and ITR distributors are Identical.</TD></TR></TABLE>
I compared the new cap i got to a b16 distributer cap and they were exactly the same thing. im guessing i might have the wrong cap for my motor. i believe my motor is a 96 spec itr. anyone know which distributer i have and which cap i need?
Quote, originally posted by 98ekhx »
the gs-r one are even the same im pretty sure the all like td84u or like td86u or td 87u or something
no, the GSR Cap will not fit an R distributor, it is 2 mm too small...
When the screw came out of my rotor and went through the R's cap I tried to use my GSR's cap, but no go...
Modified by kpop at 3:18 AM 4/2/2007
Modified by kpop at 3:19 AM 4/2/2007
Old Apr 2, 2007 | 09:23 AM
kpop's Avatar
someone help
Old Apr 2, 2007 | 06:15 PM
kpop's Avatar
i just read my distributor and it says "Td-81U". Can other members please confirm which distributor i have. thanks
Old Apr 3, 2007 | 11:49 AM
kpop's Avatar
i cant believe it. none of the vets in here can find me a solution or an answer.
Old Apr 3, 2007 | 11:32 PM
NBPdEeCeE's Avatar
* B A N N E D *
i'd like this info too. since i'm gonna need to do mine soon
Old Apr 4, 2007 | 12:21 AM
neo_'s Avatar
Default Re: wrong distributer cap? (NBPdEeCeE)
Okay boys and girls. Here is a sure way to check. Go to Len's online Acura Parts site. Then go select ITR, look at the distributor section, and check the part number for the cap then go look at the GSR distributor section and check the part number for the cap. Then, the most important step.... compare part numbers. Here we go, I'll save you some time and link you directly:
ITR:
http://www.barancoacuraparts.c...dIrno=
GSR:
P.S: If you are reading this Len, send me a free short block or something for the free publicity you just got.
Old Apr 4, 2007 | 12:34 AM
kpop's Avatar
okay finally found a cap that works. the cap for the 96-2000 Integra Ls fits my itr distributor(TD-81U)
Old Apr 4, 2007 | 03:22 PM
erikiksaz1's Avatar
I wonder if you had a distributor king dizzy. Those itr units use LS caps and rotors, supposedly. My ls cap and rotor will be coming soon, so I'll see if it fits.
Old Apr 4, 2007 | 04:11 PM
kpop's Avatar
Default Re: wrong distributer cap? (erikiksaz1)
i believe the itr rotor will work for all of the itr dizzy's. so whenever i change out my cap n rotor ill be using the 96-00 ls integra(cap) for the rotor 00-01 Type r
Old Apr 4, 2007 | 04:38 PM
gato5254's Avatar
i have a 96 jdm itr i just buy 00 itr parts i think those will work i have the old rotor and cap here some where i'll look at them tonight and put down there info
iheartintegras
Apr 24, 2007 09:19 AM
hackish
Feb 28, 2006 10:06 PM
joeymachado
Nov 13, 2003 10:48 PM
SIINSI
Aug 5, 2002 09:33 PM
D
Oct 6, 2001 12:52 PM
