Window rattle
Old Nov 3, 2002 | 11:55 AM
rockwilda's Avatar
Default Window rattle
is it just me or does everyone's window kind of stutter or rattle when you roll it down after it rains?
doesn't happen anytime else except after a good sprinkle or pour. im pretty nothing's wrong with the windows but im just curious why this happens. TIA
Old Nov 3, 2002 | 12:10 PM
Q-OnE's Avatar
Default Re: Window rattle (rockwilda)
everyone's window rattles. i hate it too. its like i can't crack the window. you have to put it about almost half way down till you can hit bumpy roads and it would stop.
Old Nov 3, 2002 | 12:14 PM
TypeR0936's Avatar
Default Re: Window rattle (NAgs-R)
Integra windows suck ***!!
Old Nov 3, 2002 | 12:17 PM
2001TypeR's Avatar
Default Re: Window rattle (TypeR0936)
I never noticed this problem ever....
Old Nov 3, 2002 | 02:01 PM
b19coupe's Avatar
Default Re: Window rattle (2001TypeR)
Happened in my Civic too. Try some shinitsu grease on the run channel-it helps.
Old Nov 3, 2002 | 03:18 PM
Dr Pooface's Avatar
Default Re: Window rattle (b19coupe)
My windows are fine.
Old Nov 3, 2002 | 03:35 PM
Revgasm's Avatar
Default Re: Window rattle (Dr Pooface)
man, its a two door...basically happens to all of them...stupid rattles
Old Nov 3, 2002 | 04:46 PM
J_Edwards's Avatar
Default Re: Window rattle (Revgasm)
I know yoshi just got done having his windows reworked by Acura under warranty.
JN who is going to take his in while still under warranty becuase his windows don't seem to roll up as speedily as they are supposed to...
Old Nov 3, 2002 | 04:48 PM
hungsteR's Avatar
Default Re: Window rattle (mr. clockwork)
My windows started to rattle recently also. But then again, maybe it's because I just put in my stereo system.
Old Nov 3, 2002 | 04:57 PM
whiteGSR's Avatar
Default Re: Window rattle (hungsteR)
mine started rattling within the last 6 months
then again, my car is a 95...
all my friend's tegs rattle too..
i guess it's either all the way down, or all the way up
seems to only be my drivers side... so far
Old Nov 3, 2002 | 05:10 PM
cheezthis's Avatar
Default Re: Window rattle (whiteGSR)
My 95 GS-R has this problem pop up every year or so...it's actually easy to fix too.
Just pop off the interior door panel and tighten up the bolts and such...works for me everytime.
Old Nov 3, 2002 | 05:32 PM
SonicGSR's Avatar
Default Re: Window rattle (cheezthis)
Im still working on mine, I have the door panels taken off and am cleaning up the tracks.
Check to see if the rubber lining along side of the window tracks are still in place, this rubber track guides the window up and down and keeps it from rattling. You will notice the problem if you roll your windows about half way and shut the door, this is the window hitting the unlined track, while your at it clean and lubricate with some silicone spray.
BTW I killed my battery while messing with the sunroof (shutting and closing)and I know it will happen to with the window so make sure you start up the car to keep the battery from draining
Old Nov 3, 2002 | 05:44 PM
Ricky Rojales's Avatar
This is "normal" for tegs.
hondaEg_808
Nov 30, 2010 12:35 AM
RBaluca.com
Aug 20, 2006 02:08 PM
ericlee303
Jun 24, 2004 06:01 PM
AznJohn33
May 2, 2004 02:33 PM
