Warning for Ignitor failure?
Old Jul 29, 2006 | 10:19 PM
Takumi Fujiwara's Avatar
Default Warning for Ignitor failure?
When my ignitor was going bad previously, my tach would jump around...
Now my car is bogging at cruising speeds at around 3k. Pressing the gas does not respond with acceleration. When I key on & off real fast while cruising, it runs normal for a few miles and then does it again. I got it home (~30 miles and must have keyed on & off atleast 10 times).
When I pull over and stop, restart the car completely, it fixes the bogging temporarily...
Must be something electrical right? Because restarting fixes it temporarily.
By the way, I am receving no CELs.
Also, I swapped out an injector the day before this started happening because it was leaking... I just don't see how this is related to my problem, probably just coincidence. Injectors are just solenoids right? They either work or they don't?
- Fuel Filter has only about 35k on it, ran on only 93 octane.
- Cap has some miles on it, but the rotor has pretty new.
- plugs have under 150 miles on them.
Someone mentioned a similar problem when their ignitor went bad... I just want a 2nd opinion before I go out spending money.
Thanks in advance!
Old Jul 30, 2006 | 04:58 PM
uNF$@#!'s Avatar
Default Re: Warning for Ignitor failure? (Takumi Fujiwara)
this is secondary to what your problem is, but you may want to consider placing your fuel filter.
Old Jul 30, 2006 | 06:21 PM
Dave_B's Avatar
Just ask Jim about his trip back from the PA meet with Jon D. He drove from PA back to VA having to stop about every 10 miles to whack the dizzy a bit before he could continue.
Old Jul 31, 2006 | 10:41 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (Dave_B)
Coil and ignitor. Your problem sounds more like the ignitor.
Old Jul 31, 2006 | 02:08 PM
Default Re: (walker111)
Thanks to ndogg for remembering what caused similar symptoms in his car from 2003.
Swapped out 2 known good ignitors with no effect.
Problem: BAD O2 sensor!
Old Jul 31, 2006 | 04:56 PM
Nataku's Avatar
Default Re: (Takumi Fujiwara)
site note, did the ignitor fix the tach jump problems? I have the same problem.
Old Jul 31, 2006 | 05:08 PM
Default Re: (Nataku)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nataku &raquo;</TD></TR><TR><TD CLASS="quote">site note, did the ignitor fix the tach jump problems? I have the same problem.</TD></TR></TABLE>
I didn't have tach jumping problems this time, just bogging.
I've been through the tach jumping around at higher RPMs, and yes a different ignitor fixed the problem. Fortunately, it was still under Distributor King's Warrany (I know it's lifetime now, it wasn't before), so they replaced my whole distributor.
I did swap out an OEM ignitor and it fixed the problem. If you've read other threads though, they recommend replacing the ignitor & coil together... or it just causes premature failure of either of the parts...
00ejhatch
Jun 28, 2013 05:32 PM
BiG_DeE
Dec 6, 2010 12:20 PM
Gsr94black
Feb 12, 2007 01:18 PM
92integraVTECgsr
Dec 5, 2004 04:15 PM
