is the vtec the same
Old Dec 19, 2001 | 07:48 PM
b18c-93's Avatar
New User
Default is the vtec the same
i have a 98 integra gsr with most of the mods i just got a 2000 type r ecu and was wondering if the vtec switchover was the same asa gsr because it does not sound likevtec is coming on at 4400 like the gsr would so was wondering if the switch over was the same.
Old Dec 19, 2001 | 08:00 PM
Digital-R's Avatar
Default Re: is the vtec the same (93gsb16a)
ITR switches at 5700 RPM's
Old Dec 19, 2001 | 08:05 PM
B2FiNiTY's Avatar
Default Re: is the vtec the same (Digital-R)
Old Dec 19, 2001 | 08:15 PM
Padawan's Avatar
Darth ModerVader
Default Re: is the vtec the same (B2FiNiTY)
Unless you have a Skunk2 or modded ITR intake manifold, the reason you aren't hearing the switch-over could be because your secondaries aren't opening up, though you say you previously heard it before the secondaries would be open. The ITR has a single stage IM, so the ECU won't be sending a signal to the selenoid to open the butterflies.
Old Dec 19, 2001 | 08:39 PM
seek167's Avatar
Default Re: is the vtec the same (SpecR0123)
how did you plug that in being that there different plugs.did you get a wiring harness.
Old Dec 19, 2001 | 08:42 PM
Dirty GS-R's Avatar
New User
Isn't the secondary intake runner on a gsr controlled by way of a vacuum and not the ecu itself.
Old Dec 19, 2001 | 08:55 PM
hybrider's Avatar
Default Re: is the vtec the same (2K1 GS-R)
from what i know the 2ndarys on the geeser are activated by the control diagrpahm (saucer looking thing) which closes at 6k, correct?
which connects to the IAB solenoid on then to the vacuum tank
Old Dec 19, 2001 | 09:29 PM
Padawan's Avatar
Darth ModerVader
Yes, vacuum is used to open the secondaries. Actually, vacuum is used to keep the secondaries closed. To my knowledge, the ECU sends a signal to the IAB controller when the secondaries are supposed to open, and the controller cuts the vacuum causing them to open. Some people choose to use an RPM activated switch for this when using a different ECU. Another solution is to run a different IM or disconnect the vacuum line to have keep butterflies open all the time. However, most people seem to feel that keeping the butterflies open normally hurts performance. HTH
RidingMark
Aug 17, 2006 03:22 PM
Norcalstoppy
Dec 28, 2002 07:11 AM
JDM CRX
Jul 1, 2002 09:48 PM
guyuenvy
Apr 30, 2002 08:30 PM
comptechgsr
Feb 28, 2002 04:43 AM
