VTEC problem
Old Oct 9, 2002 | 02:40 PM
01-1293's Avatar
Default VTEC problem
i've noticed that vtec sometimes doesn't engage in 2nd and first gear.....but it always engages in third....anyone know what the prob could be?
Old Oct 9, 2002 | 02:42 PM
Chris N's Avatar
Default Re: VTEC problem (01-1293)
Is your car properly warmed up? More specifically, oil temp/pressure must be up. If you are in a very hard corner, it is possible VTEC won't engage. If this happens when the engine/oil is fully warmed up, it is probably something else.
Old Oct 9, 2002 | 02:43 PM
01-1293's Avatar
Default Re: VTEC problem (1107)
Oil was at proper temp.........i was turning slightly trying to vtec it in 2nd but it didn't engage
Old Oct 9, 2002 | 02:46 PM
Tommy_Gunns's Avatar
Did you check your oil level? Get your dealer to look at it.
Old Oct 9, 2002 | 02:48 PM
01-1293's Avatar
Default Re: VTEC problem (Tommy_Gunns)
i checked my oil level immediately.........everything was fine
Old Oct 9, 2002 | 02:49 PM
92TypeR's Avatar
FSAE
Check your oil first. Then check any of the wires going into either the VTEC solenoid or the VTEC pressure switch, if any of those have a loose contact, they may not work under fast acceleration (usually first and second gear).
Old Oct 9, 2002 | 03:00 PM
rated_r's Avatar
I had a problem once v-tech never engaged, so i took it to the dealer and they said that my timing needed to be adjusted, so they fixed it no problems since then, but the oil temp and oil level reply`s are very correct always check those
Old Oct 9, 2002 | 03:03 PM
01-1293's Avatar
Default Re: VTEC problem (rated_r)
ya thats the first thing that came to my mind so i checked out the oil right away...........i had been driving for 15 mins so temp wasn't the problem
tigasin
Nov 14, 2008 11:58 PM
em1mata
35
Dec 30, 2007 04:51 PM
h22a1_julien
Aug 27, 2007 01:44 PM
andysila
Apr 17, 2005 11:24 AM
99scivic
Jun 1, 2004 11:09 PM
