vtec problem
Old Dec 15, 2005 | 08:47 PM
b16racer23's Avatar
Default vtec problem
i have a 98 acura integra type r, and i replaced the motor in the car with a 2000 type r motor, vtec dont work and the rpm gauge dont work ethier. no check engine light code ethier
Old Dec 15, 2005 | 08:53 PM
Mythias's Avatar
Default Re: vtec problem (b16racer23)
Did you check the harness and dizzy? What ECU are you using and with what harness?
Old Dec 15, 2005 | 08:56 PM
Haleiwa-Brando's Avatar
Do you have four quarts of oil in the engine?
Old Dec 15, 2005 | 09:09 PM
b16racer23's Avatar
Default Re: vtec problem (Mythias)
2000 itr harness, i thought its just plug an play. p28 chipped ecu with jumper, work great on the 98 r motor i had in there before
Old Dec 15, 2005 | 09:19 PM
nholmes's Avatar
Default Re: vtec problem (Haleiwa-Brando)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">Do you have four quarts of oil in the engine?</TD></TR></TABLE>
Old Dec 15, 2005 | 09:28 PM
Mythias's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16racer23 &raquo;</TD></TR><TR><TD CLASS="quote">2000 itr harness, i thought its just plug an play. p28 chipped ecu with jumper, work great on the 98 r motor i had in there before</TD></TR></TABLE>
The 2000 ITR harness is OBD2B. Your p28 ECU for a 98 ITR would be OBD2A. Maybe that is the problem?
Old Dec 15, 2005 | 09:38 PM
program's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mythias &raquo;</TD></TR><TR><TD CLASS="quote">
The 2000 ITR harness is OBD2B. Your p28 ECU for a 98 ITR would be OBD2A. Maybe that is the problem?</TD></TR></TABLE>
Old Dec 15, 2005 | 09:41 PM
mod dthispny's Avatar
are you poping vtec with oil pressure low?
Old Dec 15, 2005 | 09:44 PM
Mythias's Avatar
Default Re: (dc4LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc4LS &raquo;</TD></TR><TR><TD CLASS="quote">are you poping vtec with oil pressure low?</TD></TR></TABLE>
I understand the oil pressure issue, however, that does not explain that fact that his tach isnt working. Thats why I thought it might be the OBD2A ECU with an OBD2B harness issue. The ECU wiring is a wee bit different between the two.
Old Dec 15, 2005 | 10:09 PM
Nervous ITR's Avatar
Default Re: (Mythias)
Not only is it a wee bit different, I don't even think that the plugs will work! Make sure you have the right conversion harness between obd2a and b and the P28.
Old Dec 15, 2005 | 10:22 PM
Mythias's Avatar
Default Re: (Nervous ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nervous ITR &raquo;</TD></TR><TR><TD CLASS="quote">Not only is it a wee bit different, I don't even think that the plugs will work! Make sure you have the right conversion harness between obd2a and b and the P28. </TD></TR></TABLE>
As far as the Male/Female ends of the harness/ECU, I always thought that the OBD2A will fit OBD2B, but it has a different wiring schematic. A OBD2 harness will not fit an OBD1 ECU(such as the P28), but since he had it on his OBD2A 98 ITR configuration, he either had the OBD2A-OBD1 conversion harness, or ordered the hondata or similar ECU with the OBD2A female sockets.
Old Dec 16, 2005 | 12:54 AM
00-501itrspec's Avatar
Default Re: vtec problem (nholmes)
Old Dec 16, 2005 | 10:25 AM
vtec.dc2's Avatar
4.25 j00 as mentioned.. check harness?
Old Dec 16, 2005 | 10:32 AM
01ITR#173DC2ning's Avatar
From: Somewhere in a DC2.... Supporting the ITR Militia, USA
Harness
Old Dec 16, 2005 | 11:34 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (01ITR#173DC2ning)
ECU=obd1
Car=obd2a
Engine=obd2b
Old Dec 16, 2005 | 12:55 PM
omiehomie's Avatar
Default Re: (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">ECU=obd1
Car=obd2a
Engine=obd2b
good call im thinking ECU issues also
si_motor_spt
Jun 18, 2008 11:32 AM
clutch1515
Jan 6, 2007 10:57 PM
GuateskateVti
Aug 21, 2005 09:18 PM
Hybrid2Be
Jul 24, 2004 03:16 PM
92TypeR
Feb 25, 2004 08:24 AM
